: normal clutch feel on manuals
JTinCA
12-27-11, 11:40 PM
My new 2012 V manual feels odd going into 1st gear from a dead stop, wondered if it was "normal" or not.
Basically it feels like as I let the clutch out and it starts to catch, there's a stuttering or tap-tap-tap soft mechanical sensation. I'd equate it to the feeling you get in some cars when the traction control kicks in the ABS to prevent wheelspin. But this happens even at idle or just over idle slow motion starts. And it happens with traction control on or off.
It's not like the engine is floundering or going to die from too much clutch too fast without enough throttle, and it happens even with RPMS up around 2500, the fastest I've tried. I have not been popping the clutch, doing hot shifts or running it hard - still babying it during break in.
It's smoothed out significantly since I got the car, but at 300ish miles it's still noticeable.
Going into any other gear, I can't feel a similar sensation, except slightly in reverse. There's no rattling or clanking like a broken gear tooth or anything, just a flutter.
My last 4 cars have all been sticks, and none had this feeling. I described it to the service rep, he said it's probably normal wear in as the clutch breaks in, but if it's unacceptable or doesn't go away by the first oil change they could take a look.
Anybody have similar experiences?
Anybody driven a V stick and a BMW 135/335/535 6 speed stick who can offer a clutch feel comparison?
Thanks
Jpjr
12-28-11, 06:40 AM
Never driven the BMW but sounds like classic clutch chatter to me. If it was happening any time other than when you were trying to engage the motor from a stand-still I might say otherwise. That said, no harm in getting it checked out because if it's simple chatter it won't go away after a month.
marktanner
12-28-11, 07:24 AM
Mine did it some when new, and it still feels like it occasionally at 25000 miles. Had it checked out, and they couldn't find anything. I have seen some other comments on this, including in a long-term review in a magazine. It always seems to get better with time. May be a characteristic of this particular clutch design, which does have a tough job having to harness 551 ft/lb of torque to 4300 lb of car. Give it some time; I predict it will smooth out substantially as it breaks in. If it doesn't or gets worse, they can always fix it under warranty.
Cadillac Cust Svc
12-28-11, 12:02 PM
JTinCA,
Vehicles do have a break in period, and it should get better over time. When you get your oil changed I would have them check in out like they mentioned. You should notice a lot smoother transition. Keep us updated.
Breanne
Cadillac Customer Service
pmsteinm
12-28-11, 01:14 PM
My wife has a 2007 335i manual. It feels completely different than the V. I get the chatter you describe if I don't get the RPMs to around 1200 when starting out. If I try to do it at 900rpm like I could with the old V I get the chatter. The 335i also has the clutch delay valve which might require the V to be driven a little different. (I'm very smooth changing gears in the V, jerky as all get-out in the BMW). But maybe that's because BMW drivers are jerks :duck:
I usually still chatter, but lately have been trying to get some more RPMs when going to smooth it out. There was a thread on this a while back (like a couple years). The theory was the twin disc clutch and the higher clamping force than the old V (since the engine out is 550lb-ft vs 395lb-ft). Most said just give a little more revs, problem solved.
Fireverm
12-28-11, 01:32 PM
I feel the same thing with my 2011 I bought in May, although describing it as being as bad as when ABS kicks would be significantly worse than what I feel and hear. Every car I have bought has been stick and while none of my other cars had this particular feel, it's never felt like it was due to anything being wrong.
porschefan1013
12-28-11, 04:29 PM
I experience a slight vibration as well, from time to time...entirely dependent on the RPM's and how I engage the clutch. I attribute it largely to the amount of power going through the transmission. It doesn't feel abnormal to me, and I certainly would characterize it as being as noticeable as ABS kicking in.
I'm at 1300 miles right now.
e6t
12-28-11, 06:13 PM
mine had it.
had the entire clutch replaced at about 2000 miles. new clutch was PERFECT for the first 100 miles then started it again... ultimately gave up and attributed it to a warped flywheel or something... maybe even glazing.
ive driven all the bmws you mentioned and none feel like the caddy. In fact, ive driven most every manual out there, including a couple lambos and ferraris and nothing felt like my v.
it did seem to feel better after the car was driven hard which made me think it was glazing. i no longer have the car and the clutch was the contributing factor.
i wouldnt have the dealer look at it. maybe take it to a chevy dealer that deals with ZR1s... otherwise the caddy dealer will F something up.
Good luck.
Thunder Gray STS
12-28-11, 09:44 PM
My family, being in the clutch business for 65 years (me personally for 27 years) have come across situations like this. Unfortunately, there are several things that can cause this. In no particular order.
1. The disc does not have enough cushion in it. The fins on the disc, looking at it from the side, should have a wave or curve in them, if not there is not enough cushion.
2. Since the center plate uses straps that attach to the pressure plate, (the center disc is sandwiched between these 2 plates), I have seen those straps allow the center plate 'bounce' against the center disc causing a not so smooth or incomplete disengagement. Usually caused by the wrong tension on the straps or the straps lose tension from heat.
3. Both discs are not disengaging at the same time.
4. The pressure plate is not torqued evenly to the flywheel causing one side to release before the other.
5. Manufacturing defect in the diaphragm ( which is the spring of the pressure plate )
6. Dual Mass flywheel worn ( probably not the case here).
7. Clutch discs stabbed on installation. Misalignment (doubtful, unless the clutch was replaced at the dealer)
8. Throw out bearing clearance incorrect.
9. Pilot bushing or bearing in the flywheel worn or improperly installed.
There is more, even going all the way back to the differential, u joints etc. it is a tough problem to diagnose.
JTinCA
04-19-12, 04:34 PM
Thanks for the detailed info, sorry I didn't notice this earlier.
JFJr
04-19-12, 04:59 PM
If you "lead" clutch engagement with a little rpm, you should solve the problem. I can induce chatter if I don't engage 1st with enough rpm. I believe that this is a characteristic of this particular clutch with such a torquey engine.
Jus
junker87
04-20-12, 12:06 AM
Thanks
I have driven plenty of E90's, and just swapped my 11 M3 sedan lease.
99.999% of modern cars have the POS dual mass fly wheels, including Cadillac, BMW, etc. I HATE dual mass because they still chatter, and they made hard and fast clutch take up difficult. I think all clutches should be like the E30, single mass goodness.
What you described seem normal.
One last thing, I love the clutch in the V, for being a modern car, the clutch is decently weighted, unlike modern BMW and their feces soft clutches. I remember one day I drove the Vagon to and from work, then decided to take the E90 M3 to whole foods, and almost put my foot through the floorboard of the M3 because the clutch WAS SO TERRIBLY SOFT.
JTinCA
04-20-12, 09:18 AM
Haven't driven an M3, but my last car was a 335i and it was a slightly softer, more linear pedal, but regardless of how fast or slow I let out the pedal, that car never gave a feeling of vibration in the driver's seat. Clutch smell on the other hand...
FWIW I did get the dealer to let me drive their only other stick V. It had the same issue, but at only about 20-25% the same level as mine (at those miles). So perhaps it is normal for this clutch, but there's a range of behavior that's all within normal and I just happen to have one towards the rough end or that sedan was close to the smooth end.
In any case I'm looking for a clutch/flywheel upgrade anyway, so hopefully I'll kill 2 birds with 1 stone.
AuxNuke
05-23-12, 11:26 PM
Hate to dredge up a month old thread but...
I just picked up my 2012 M6 Coupe and the vibration / shimmy in first gear is VERY bad. Its next to impossible to slowly launch the car without the clutch vibrating, no matter what the revs. I guess trip back to the dealer is in order. This does not happen when shifting slowly in any other gear with the exception of reverse where there is a mild vibration. Has anyone had this issue permanently corrected by the dealer? Thanks in advance.
- Aux
SoCalCTSV
05-24-12, 01:05 AM
I have it but get the RPMs up and it's not as bad. Sometimes the more I think when I shift, the worse it gets.
JTinCA
05-24-12, 11:12 AM
I'm at about 3200 miles now, and mine has pretty much gone away. It's definitely not buttery smooth, but it no longer feels broken or unbalanced. I'd say "unrefined".
Cadillac Cust Svc
05-29-12, 11:00 AM
- Aux
AuxNuke, I apologize for not seeing this thread sooner! Have you had a chance to consult your dealership about your vibration concerns yet? If you still have lingering questions after your dealer visit, please feel free to send me an email anytime at Katie_Lucille@gmexpert.com and I can look into this further for you. I'm sorry to see you were experiencing this so shortly after purchase!
Best,
Katie
cdog533
05-29-12, 12:02 PM
Hate to dredge up a month old thread but... I just picked up my 2012 M6 Coupe and the vibration / shimmy in first gear is VERY bad. Its next to impossible to slowly launch the car without the clutch vibrating, no matter what the revs. I guess trip back to the dealer is in order. This does not happen when shifting slowly in any other gear with the exception of reverse where there is a mild vibration. Has anyone had this issue permanently corrected by the dealer? Thanks in advance. - Aux
This is normal. A couple of things to try:
- Use more revs, dig deeper into the clutch.
- Try some varying launch techniques. More throttle, more slip, etc.
- Clean up your clutch a little. This means REALLY slip it (using like 4K rpms) on a couple of launches.
AuxNuke
05-29-12, 04:27 PM
Best,
Katie
Cadillac Customer ServiceI am taking the car in this Thursday for service. I will let you know the outcome.
- Clean up your clutch a little. This means REALLY slip it (using like 4K rpms) on a couple of launches.Normal? Do you mean for this vehicle? I ask because all of my cars over the last 15 years have been manual and NONE of them have felt like this.
JFJr
05-29-12, 05:14 PM
Normal? Do you mean for this vehicle? I ask because all of my cars over the last 15 years have been manual and NONE of them have felt like this.I increase the rpm slightly as soon as the clutch pedal comes off the floor, gradually increasing it as the clutch engages. This technique always gives me smooth launches. The LSA has tremendous torque and the "V" is heavy, so the clutch is probably more challenged than in other cars.
Jud
M5eater
05-30-12, 07:59 AM
I have what I would consider a slightly annoying vibration comming from a stop in first gear if I don't use a lot of throttle or try to ease out with none at all, but I considered it a normal characteristic of a dual-disc clutch and an engine making 250ft/lbs torque @ 1,000 rpm. Have you owned multi-disc clutches before? I haven't so I couldn't comment on if it's a problem or not.
All I do know, is that both my B5's with heavy clutches never transistioned smoothly from a stop without some throttle.
Rich Browne
05-30-12, 08:57 AM
I have posted this before. When my car is parked "nose up" the clutch is decidedly smoother on activation. If it is parked tail up it has a very catchy feel and requires greater RPM to "feel" smooth. As odd as this sounds, I always park "nose up" and am very happy with feel, ya, make me sound like a wack....
cdog533
05-31-12, 11:16 AM
Ya, normal for this car. My V1 had a real clunky clutch, the V2 is more solid, but harder to modulate. When it doubt, up the revs and slip the piss out of it for a clean launch.
