View Full Version : DTC C0561 - 71 and P0300 - 00 plus MIL and Service StabilyTrac on DIC
Jochen
12-21-11, 11:03 AM
Need some help on the following issues:
Last night i got the following symptoms while driving for about 45 minutes:
- 4-5 times a rough running engine with the MIL turning on. After a few seconds, MIL turned off again
- Traction Control Lamp turned on for a few seconds, then off again. Followed by messages like "Service Stabilytrac" or "Stabilytrac off" in DIC.
Today i checked DTCs and Missfire information with a Tech2 while testdriving. Results:
ECM: P0446 and P0300-00 (thats the Missfire DTC)
EBCM: C0561H-71 and U0101C-00 (i guess those are the DTCs for the Stabilytrac thing)
While testdriving for 1.5 hrs everything was fine, beside one short "Service Stabilytrac" Message for 2 Seconds. Thats it.
I looked up the missfire history Data in the Tech2:
Cylinder1: 0
Cylinder2: 318
Cylinder3: 35
Cylinder4: 0
Cylinder5: 2144
Cylinder6: 20
Cylinder7: 941
Cylinder8: 0
The counter was icrementing, however, no accutal missfires were detected while driving, the history numbers stayed all the time like that.
Does anyone has an idea how to approach the problem?
Any help is appreciated! Many thanks in advance!
Jochen
Jochen
12-24-11, 08:11 AM
Good morning... and merry christmass... :-)
I was driving around for two days now and the symptoms did not come back.
Anybody has an idea what could have caused the problem? Maby water somewhere in the engine compartment that messes up the electronics?
Jochen
acreech1
12-27-11, 03:27 AM
Theres a number of 2007-08 escalades with faulty battery cables that are causing the same issues. Check with your dealer to see if you're covered. Im not sure if it was a recall or not.
Big Windy Ext
12-27-11, 07:42 AM
I don't remember the codes, but they differed from the actual problem, an evaporative purge solenoid,but my show started with traction control service. It was really heartning to hear the displayed codes are irrelevant to the actual code.A whole bunch of nothing for a simple problem.
Jochen
02-15-12, 07:21 AM
Thanks very much for responding!
The problem disappeared for almost two months. I already thought i am over with it... Well, not really.
Yesterday the same symptoms came back. And it did start like Big Windy EXT said with the traction control service info. Then the rough running engine, MIL turned on. Then off again, then on again...
Did you fix the problem by yourself or in a garage? What did you replace/repair?
Many thanks for your help!
Best regards,
Jochen
Jochen
02-17-12, 03:39 PM
ttt
Anybody experienced the same problem and found a way to fix ist?
Jochen
02-26-12, 09:17 AM
Hi,
trying a different approach.... Yesterday i checked all related parts and found two cracked spark plug wires.
Hope that caused the missfire/problems... See pics!
I will let you guys know if the problem came back after repacing the wires!
Jochen
2013-Enclave-owner
12-30-14, 01:32 PM
I know this is old but did it ever get resolved? I have a 2013 Buick Enclave that is going into limp mode and my wife was almost rear ended once when this happened. Our's also shows C0561 symptom 71. We are getting Service Stabilitrak, Traction off and along with a flashing SES light. It runs bad when this happens and the speed is suddenly reduced to about 35mph. Once when she was at a stop light it happened and it would not really even move, it was shacking pretty bad. I have brought it to our dealership a couple times but they do not know what is wrong with it. They are telling us to bring it back when it happens again without turning it off.
Cadillac Cust Svc
12-30-14, 06:20 PM
Hi 2013-Enclave-owner,
Im very sorry to hear that you are experiencing these issues with your Enclave. I see you've already been in touch with your dealership though the root cause has yet to be determined; if you would like for us to reach out to them to ensure all resources are being utilized, please send us a private message with your VIN, contact information and the name of your preferred dealership.
Sincerely,
Shane M.
Cadillac Customer Care
Jochen
06-23-15, 07:35 AM
Sorry for the late response....
Yes, the cracked spark plug wires caused the problems. Unfortunatelly the cats got destroyed from the unburned gas... So beside the wires, i had to replace the catalytic converter...
Since i replayed it in 2012, no more problems on rough running engine...
