: Interior dome lights
12-20-11, 12:30 AM
Question for you guys. If I open my rear doors on my escalade my interior dome lights won't turn on but they do turn on with the front doors. Is there a certain button I'm needing to push or what am I missing?
12-20-11, 06:21 PM
My 2010 EXT dome lights come on when only the rear door is opened. Check the manual, I'll bet there is a setting you need to change if you want the dome lights on from the rear.
Cadillac Cust Svc
12-22-11, 01:56 PM
(Dome Off): Press the button in and the dome lamps remain off when a door is opened. Press
the button again to return it to the extended position so that the dome lamps come on when a door is opened.
Entry Lighting
Your vehicle has an illuminated entry feature. When the doors are opened, the dome lamps will come
on if the dome override button is in the extended position. If the dome override button is pressed in, the
lamps will not come on.
This is what I found in the manual on page 3-22. If your vehicle is operating a different way then what is listed above I would contact your local dealer to have it diagnose and/ or repaired.
Cadillac Customer Service
