:bighead: Hi My turnsignals just stopped, purchased a
flasher unit but where does it go? My husband just
looked in the area around the fuse box, could not find.
Thanks Joanne
Snyder81
09-05-03, 03:19 PM
Thanks Joanne
I think you are just talking about replacing the bulb. To do that, you should be able to remove the plastic cover over your turn signal with a torx driver and just replace the bulb after you remove the plastic housing. Is the bulb what you are trying to replace?
Katshot
09-05-03, 03:36 PM
The flasher's behind the left side of the dash on the fuse/relay block bracket.
