: Weird headlight problem - what could it be?
12-13-11, 01:38 AM
Tonight I noticed that both my headlight and fog light on the passenger side are out. I checked the fuses and they look good. Very doubtfull that both bulbs burned out at the same time. How can both be out? Is there something I missed?
12-14-11, 02:34 AM
Probably the fog burned out first and you didn't notice until now.
Sent from my ADR6400L using Tapatalk
12-14-11, 02:45 PM
That could be true. Good point.
I only want to change my Pasenger headlight (by going under the fusebox). Which headlight bulb would look closest to the stock bulbs? This way it will match better.
Would this be good?
12-15-11, 01:28 AM
12-15-11, 01:52 AM
Silverstars are just a little different then stock. Not much, but just a little. I would change both out at the same time.
If your wanting to just change the one, go to your local parts shop (napa, pepboys, etc.) and just grab a philips bulb or whatever the store brand is.
12-15-11, 10:38 PM
Thanks. I appreicate it. Ordered on Amazon (better deal). This weekend I will attempt to remove fusebox and get the the bulb.
