View Full Version : ? about Platinum headlamp adjustment screw
murphy
12-11-11, 07:54 PM
Just curious as to what adjustment the plastic torx head on the platinum headlamp assembly performs ? Up/down or in/out or other and is this the only adjusting mechanism ?
tia
hcvone
12-12-11, 08:21 AM
Yes it is but you can not use a male torx like you can on the HID light adjustment of the standard Escalade, you have to use the female or external torx socket size E8, screwing in or down raises the lights if memory serves me correct, you just have up and down adjustment
http://buy.snapon.com/catalog/item.asp?P65=&tool=hand&item_ID=84630&group_ID=22576&store=&dir=catalog
murphy
12-12-11, 09:37 AM
Thanks Carl..I think a 10mm socket fits also..
48Dodge
12-12-11, 11:09 AM
Just adjusted my non-platinum headlights this weekend. They were both way too high. I used a bit driver handle to make the adjustment. It fit the adjustment posts very snugly. I believe bit driver bits are 1/4"
