: 2000 deville using oil HELP !
polorico
12-06-11, 11:52 PM
Whats up fellow caddy heads.
I have a 2000 cadillac deville that i bought with 98k on the clock , now it has 103k coming up on a routine oil change.
i put 10-30w mobile 1 high mileage synthetic oil in it.
I got a "Check oil level" message on the dash board , i checked my oil and it was running pretty low just barley had any oil on the dipstick , It had done this 1 other time prior to this , the second time it has done it since the Oil change .. So i put 5 quarts in it to get it back to where it needs to be .......
I never see any leaks on the concrete or any type burning or smells .....
I have also had 2 1996 devilles that had this type of problem ....
Car runs great , Just seems to use Oil , My step dads , and my fear is that this could cause alot of problems down the road.
Any ideas why it is using this oil ? maybe a oil manifold slow leak ? My oil change is due in about 300 miles and it has used like 5 quarts since then.....
Any help would be great. Thanks...
KNCadillac8898
12-07-11, 12:09 AM
Mine takes 5W-30, says it right on the cap. Are you sure the 2000 is 10W? I know the 90's were.
Also, the Northstar takes exactly 4.5 quarts to fill I believe.
iruleyounow
12-07-11, 12:27 AM
Its 5w-30 man.
KNCadillac8898
12-07-11, 12:45 AM
Whoops, meant to type 7.5 quarts up there. LOL. I'm going to bed.
polorico
12-07-11, 12:48 AM
It says 5W-30W on the cap , i have a friend who works in a big cadillac dealership in dallas and told me that it does not matter if i put 5 w or 10 w
Also it takes about 7 quarts , thats what the oil change people have told me.
Any other input ? i just dont want to have a problem down the road.
basscatt
12-07-11, 01:26 AM
:welcome:
WRONG!
Our Cadillacs take exactly 7.5 quarts including the .5 qt for the oil filter.
When you get the "check oil level" warning you USUALLY have 6+- quarts remaining - you need to add about 1.5 quarts - I hope you didn't dump 5 quarts in it!
The Northstar motor is known to use oil - if you put in any more than 7.5 quarts it will quickly be sucked up and burned - most of us only fill them with 7 quarts - look at the "hash marks" on your dipstick - when properly filled, the oil level will be in the MIDDLE of the hash marks.
Go up to the Technical Archives at the top of the page and read up on oil consumption and full throttle acceleration.:bouncy:
Are you taking advantage of the OLM (Oil Life Monitor) - or are you wasting money, oil and time changing your oil every 3000 miles?
---------- Post added at 12:15 AM ---------- Previous post was at 12:12 AM ----------
I HOPE you are using 7.5 quarts in your DTS!
---------- Post added at 12:26 AM ---------- Previous post was at 12:15 AM ----------
If this were true - Cadillac would say USE EITHER 5W OR 10W - 30
It says 5W-30W on the cap -
and it says this for a reason
is he a porter or car-wash guy?
Ya - don't listen to your friend! - Feel free to ask us!
polorico
12-07-11, 02:43 AM
Thanks for the input
so from here on out put only 5w - 30 in it ???
there was little to no oil on the dipstick , So i did put 5 quarts in it ...
when i took the dipstick back out , it was right where it needs to be in the hashmarks and it said something like "where the oil needs to be " but in fancy terms.....
All my north star motors have used oil before , and i would always just add oil when ever the sign came up...
So my question is
should i just add oil when ever it says "check oil level" ? im just worried that its either burning it , or slow leaking it somewhere. I have not found any evidence on the concrete at the house , or when i park at school .... I am just worried it has no oil in it when i didnt see any on the dipstick...
Also yeah i just change my Oil when ever the milage is due , It reads it has 35 percent oil life left , When would you recommend to change it ?
ternstes
12-07-11, 06:18 AM
It took 5 quarts to get to midway on the hash marks on the dip stick? If it is burning that much oil, you could damage the catalytic converter, but I would first check externally for leaks or seepage. Check around the valve covers, timing cover, oil filter adapter, oil cooler lines (if equipped), half case seal, oil pan, rear main seal. A leaking oil manifold would could both a loss of oil pressure and perhaps oil level if we are talking about the same thing (oil manifold distributes pressurized oil to the mains and heads). Does tail pipe area look black/covered with soot?
KNCadillac8898
12-07-11, 07:56 AM
Lol, I mis-typed it. I checked the thread later and reread my post and had a WTF did I write moment. I corrected myself up above.
Submariner409
12-07-11, 09:31 AM
For a 2000 Northstar engine, 1.5 quarts of 5W-30 oil will bring the level from the tip of the dipstick to the proper level of halfway up the hashmark. DO NOT attempt to keep the oil level at the top of the hashmark - at the OPERATING RANGE mark - the engine will rapidly burn off the overfill.
If you added 5 quarts of oil to a Northstar engine with "barely ..... any oil on the dipstick" then the engine is now overfilled by about 3.5 quarts - a total of 10 or so. Bad move.
2000 - 2004 Northstar:
<=== ADD= XXXXXXXXXX = OPERATING RANGE ===========oo===================================== ==O
Ranger
12-07-11, 11:29 AM
5W30 or 10W30 is just fine. Technically it is spec'd for 5W30, but that's to appease the tree huggers. I have never run anything but 10W30. Either is just fine.
The correct oil level should be in the middle of the hash marks, not at the MAX mark.
When the oil level drops off the tip of the dipstick and the CHECK OIL LEVEL message comes on you still have 5.5 qts of oil left in the crankcase.
Change it when it tells you to at 10% or less.
You're not gonna have any problems down the road. It's just the nature of the beast. Go to the Technical Archives at the top left of the page and read up on oil consumption. It's all explained there.
---------- Post added at 10:29 AM ---------- Previous post was at 10:03 AM ----------
Please do not double post. Threads merged.
Submariner409
12-07-11, 02:20 PM
Troops, The owner's manual states that 10W-30 is acceptable for use in ambient temperatures above 0 degrees F in the 2000+ Northstars......yes, 5W-30 is the recommended viscosity but running 10W-30 won't hurt a thing.
When all else fails, read the directions................:sneaky:
Ranger
12-07-11, 04:29 PM
I would not be concerned with 10W30 even in below zero temps. What did we do before 5W30 was around?
polorico
12-07-11, 10:12 PM
Good looks guys
Then its using that much oil then.
so from here on out i will only put 2 quarts in it.....
My dude who works in the dealership told me it was the oil manifold
any idea on how much the part is ?
i get free labor : )
tateos
12-07-11, 10:20 PM
Also, I suggest you start using conventional oil - unless the syn oil is free too - your oil filler cap says 5W-30, but either 5W-30 or 10W-30 is probably fine - especially at 103K miles.
I think the oil manifold is 100 something dollars, but the engine has to come out and be disassembled to replace it. That's not a real common problem - there was a TSB for rings on the 2000, if memory serves...???
Ranger
12-07-11, 10:20 PM
That is a LOT of free labor.
polorico
12-07-11, 10:59 PM
So just watch the oil and add when the check oil light comes on ????
Will it cause problems down the line ?
polorico
12-08-11, 01:05 AM
So i just got back from running to the beer store
when i got back i noticed that there was oil on the ground :hmm::hmm::hmm::hmm::hmm:
I did over fill it though when it said "check oil level" and put all 5 quarts in it ....
Is that the car just tossing the excess amount out ???? i have never seen anything on the ground before.....
Submariner409
12-08-11, 08:19 AM
Oil level: Check it like you're supposed to; screw the oil level light and warning. Those idiot lights are for someone who has no idea of where the engine is, much less the dipstick. Use the dipstick and don't just throw some oil in it - do it intelligently. Just because the trunk says "Cadillac" does NOT mean that you neglect normal vehicle checks.
Once a week, open the hood. Check your engine oil level, brake fluid level, coolant level, windshield washer fluid level and check the accessory belt and water pump drive belt for tightness and general looks. Check the tire pressures at 30-32 psi, cold (never warm). Plan on checking transmission fluid level after at least a 15 mile drive while the engine/transmission is hot, not warm, with the engine idling in P on a level surface. There should be NO FLUID on the stick with the engine OFF. It's a dry sump transmission. Occasionally, when road surface and traffic permits, do a fairly fast stop from 25-30 mph with your hands off the wheel. If the car stops in a pretty straight line, good; if it veers to one side, you have suspension, steering or brake problems.
If the car is 5 quarts overfilled the excess oil can be coming from anywhere including pan seals, crankshaft end seals, oil filter adapter, dipstick tube lower end, valve cover seals.........anybody's guess.
Ranger
12-08-11, 11:02 AM
NO it will not cause any problems down the line. Did you read post #11? There is plenty of oil in the engine when the message appears.
polorico
12-10-11, 05:04 AM
thanks guys , im not the best with cars but i take care of them the best i can !
Yeah so i noticed the oil leaks on the ground are starting to slow down.
So im guessing that was the extra amount of oil leaking out.
Mark D
12-10-11, 09:08 PM
It's not uncommon for Northstar engines to use excessive oil. There is a GM fix for this if it is caused by oil seeping past piston rings. Ask your dealership friend about it.
I'm sort of curious as to why you wait until the low oil light comes on before you bother to check your oil?
What if that light stopped working for one reason or another?
It really isn't a bad idea to check that dipstick once a week, or even every other week. That makes it much easier to get a good grasp on what your engine is doing with regard to oil consumption.
Just my own opinion, though. I know most people today don't really bother with dipsticks, on cars, or other types.
Mark D.
Submariner409
12-11-11, 10:42 AM
The general attitude among most automobile drivers nowadays is.............."It's a [pick your brand]: I don't need to check or maintain anything - it does it all by itself."
Post #19
iflipcars
12-11-11, 02:10 PM
Use the DIPSTICK when adding oil !! :tisk::tisk:
