: Did anyone do any Leds install in the Front as well as Leds in the interior?
doctorwill
12-06-11, 10:09 PM
Any pics?
Just curious if anyone did anything special in regards to their Escalade with LEDs lights exterior/interior? Any pics?
Im about to get my Escalade custom with Leds...
Thanks
Will
MrHolland
12-06-11, 11:26 PM
Yeah, a gentleman with the name matchn_toyz has done some things to his. Just search a little, its in here
StevieT
12-06-11, 11:42 PM
Tons of posts on this
hcvone
12-07-11, 07:14 AM
My trucks are 100% led, have platinums so the headlights are done, added full interior, backup, puddle lights, license plate and fog lights all from VLED, have this setup in all 3 trucks. Works and looks great
ELUSIVE
12-07-11, 08:44 AM
hcvone - Do you know which bulb you used on the inside of the driver and passenger side front doors?
I've had issues finding which LED bulb will fit in that opening.
stater02
12-07-11, 09:24 AM
I did a full LED/HID conversion. I used all LEDs with the exception of the fog lights and the DRL (used HID for these.) I've read posts on here that have stated that HID will burn out the Caddy-logod cover on the middle light, but I have not found that to be true in my case.
I replaced the top lights (parking lights) with LEDs. I did 4300K all the way around, as it's the closest to stock there is. Anything more than that and you'll get more blues/purples.
As for your question on the doors, I used 168s there. I had to use a utility knife to trim just a little bit of plastic off the resistor at the base of the LED.
I have a ton of pictures of all of this, as my buddy is doing a write up on this for his aftermarket car parts website. Let me know if you need any of them and I can post.
hcvone
12-07-11, 09:49 AM
I used 6k on the interior color, I believe these are the same bulb as the puddle lights, or at least what I have listed, but I pulled one out of the door to double check #194_4_HPF_W_6K
http://www.v-leds.com/Interior-LED-Bulbs/Dome-Map-LED/White-LED/6K-WHITE-4-LED-2-WATT-p5768086.html
richw3533
12-07-11, 11:17 AM
I did with exception to my HID's in LED's on BADCAD, here is the link to check out some pics. I will be posting all once the interior is finished in suede.
http://s252.photobucket.com/albums/hh12/richw3533/BADCAD/
ELUSIVE
12-07-11, 12:44 PM
Thank you!
