: New help with rims and tires.
wrinkles88
11-28-11, 09:51 PM
I am looking to buy some new rims and tires early next year and would like some help and input.
I am looking at getting Boss Wheels model 331 20 inch. My first question is would either of the following fit:
5 on 115mm +14 mm
5 on 4.25/115mm +30 mm
83183
I'm guessing the second one would but the "4.25" throws me off because I have no idea what that means.
Now for tires, I am looking at some Toyos. The two I am looking at are Proxes T1R and Proxes 4. Here is the following information on them:
Proxes T1R
245/35ZR20 95YRD OAD: 26.77 in.
245/40ZR20 99YRD OAD: 27.72 in.
Proxes 4
245/35ZR20 95WRD OAD: 26.76 in.
245/40ZR20 99WRD OAD: 27.64 in.
Now I am thinking the Proxes 4. But for either of those tires would the 27 inch plus diameter fit with no rubbing?
I hope that makes sense and thanks for the help.
shartmann
11-30-11, 10:59 AM
I have a set of Boss wheels with a Nitto NT555 245/35ZR/20 95W... on a 2008STS4 I have never had any problems with any rubbing while turning or bumbs.... But I lost A LOT of ride quality. I didn't notice it until I switched back to stock (Winter coming)... But the biggest problem I had is I blew out both front shock absorbers. I don't know if it was from the weight of the wheels with poor road quality...OR just the weight.... I got lucky,... IT was covered under warranty... if I would have had to pay it would have costed me $1,800.... Just thought I would let you know the problem I just had....
wrinkles88
11-30-11, 11:08 AM
Thanks I appreciate the in put. That is something I didn't think about.
Can anyone recommend me something similar to that style of rim with less weight?
rics8
12-02-11, 11:37 AM
they should be less in weight than stock. the prob might have been an improper wheel aliment. and air.
anything under ???/45/20 will not rub and give you full wheel turn. :) the ride will vary because of less rubber.
try to find a tire with enough rubber side wall and you should be ok. :thumbsup:
scott9001
12-03-11, 03:57 PM
not true are you telling me i can buy like a 355/45/20 and not rub i highly doubt it keep it reasonable and you will be fine lol only said this becuase i felt like being a dink lol not hating lol
scott9001
12-03-11, 03:58 PM
btw that wheel looks horibly cheap you can find better!
wrinkles88
12-03-11, 11:44 PM
Can you recommend anything than?
rics8
12-04-11, 05:40 PM
I Said under. Thank you
rics8
12-04-11, 05:41 PM
245/40 or 35. Is a safe bet.
