: Headlight aiming
ESCALADE132
11-25-11, 09:23 PM
Can someone tell me how to aim my headlights in my Escalade and do I aim them on my garage to make them even and far back from the garage should I be? Is there a knob or something?
Thanks
murphy
11-25-11, 09:56 PM
The area should consist of a level surface large enough to allow for a vehicle and an additional 7.62 m (25 ft) as measured from the face of the headlamps to the aiming screen.
The screen should be a wall or other flat surface at least 1.52 m (5 ft) high by 3.66 m (12 ft) wide with a matte white surface well shaded from extraneous light, and 90 degrees to the floor (a). The screen should be provided with a permanent vertical reference line 0.61 m (2 ft) from the left edge of the screen, 2 laterally adjustable vertical tapes, and one vertically adjustable horizontal tape.
After the aiming screen has been set up and located, paint or tape a reference line on the floor 15.24 m (50 ft) from the vertical reference line on the screen. This line should be perpendicular to the aiming screen and a mark placed at 7.62 m (25 ft) from the screen.
Headlamp Aiming Procedure
Align the left tires of the vehicle with the reference line extending from the screen with the headlamps aligned with the reference line.
Remove any snow, ice or mud from the vehicle.
The vehicle should be fully assembled and all other work stopped while the headlamp aiming is being done.
The vehicle should contain cargo or be loaded to represent normal vehicle use.
Tires should be properly inflated.
Rock the vehicle to stabilize the suspension.
Measure from the floor to the center of the lamp bulb on the vehicle. Some lamps have an aim dot marked on the lens.
At the screen, measure from the floor and place the horizontal tape at the measured distance.
Measure from the reference line on the floor to the left headlamp bulb centerline (1).
At the screen, measure from the reference line and place the vertical tape at the measured distance (2).
Measure from the reference line on the floor to the right headlamp bulb centerline.
At the screen, measure from the reference line and place the vertical tape at the measured distance.
Turn the headlamps ON.
Block the light from projecting onto the screen from the passenger side headlamp. This will allow the cutoff in the beam pattern from the drivers side to be more pronounced for easier aim verification.
Important: DO NOT cover the headlamp, this may cause excessive heat build up.
On this vehicle you will be verifying the aim of the vertical cutoff on the right side of the lamp vertical bulb centerline as it is projected onto the aim board.
If the location of the cutoff projected onto the board differs from figure 4 then an adjustment to the beam pattern location is necessary.
Adjust the vertical headlamp adjustment screw until the Right Gradient Line (Cutoff Line) is set at the Horizontal Axis within +/- 2.0 inches (2) measured at 25feet.
Verify proper aim location.
Repeat the aiming procedure for the passengers side headlamp while blocking the light from projecting onto the screen from the drivers side headlamp.
