: Power retractable running boards.
c1crx
11-23-11, 07:24 PM
Quick question do the power running boards have any sort of adjustment when it comes to how close they rest against the body when retracted? I've noticed some escalades have less of a gap compared to mine and I think it looks better.
2007XTSDub
11-24-11, 09:12 AM
I noticed the samething on others. Im going to ask dealer to look into it.
Cadillac Cust Svc
11-25-11, 09:54 AM
Hello 2007XTSDub,
I will do some research as well, but keep us updated as to what the dealer finds out for you.
Breanne
Cadillac Customer Service
prosseda
11-26-11, 01:23 AM
None of the brackets or frame have any adjustment. Only the front to rear position of the board can be changed. I know this because I had the complete board and frame and brackets torn down to the motor etc., and then reinstalled everything.
Mrbruin2k
11-27-11, 05:57 PM
Is it an easy adjustment front/rear as I would like to move back a bit so I don't rub on my 24" tires
MrHolland
11-27-11, 06:06 PM
Yes.
hannity
11-27-11, 09:27 PM
Mine are right up against the body of the truck. No gap. But I have turned mine off because even after warranty repair work they work when they want to. I figure they can't get any worse if I don't use them.
2007XTSDub
11-27-11, 10:05 PM
Pic please. :)
Sent from my SAMSUNG-SGH-I997R using Tapatalk
c1crx
11-27-11, 11:37 PM
I wonder why some escalades sit like that with less gap than others :/
2007XTSDub
11-28-11, 08:39 AM
My guess is lack of quality control! The mounting holes for the boards are not all in the same spot for all Escalades. Anyone else want to post pics?
hannity
11-28-11, 04:04 PM
I was at the mall today and someone had an escalade that was not a platinum. But, it had power running boards. I went out of my way to walk next to it so I could get a look and there is a gap. However the person may have put them on as aftermarket or may have been dealer installed. Because like I said it was not a platinum, didn't have the wheels and it didn't have LED's.
murphy
11-28-11, 07:44 PM
Mine:
http://gpchase.zenfolio.com/img/s11/v30/p530268873-6.jpg
http://gpchase.zenfolio.com/img/s11/v27/p671057575-6.jpg
http://gpchase.zenfolio.com/img/s11/v31/p1042293876-6.jpg
2007XTSDub
11-28-11, 08:55 PM
Same gap i have on mine. I have seen others that are nice and tight up to the body. Looks much better IMO.
hcvone
11-29-11, 06:39 AM
Mine:
My three all look like the Murphy mans truck:) Seriously does that truck leave the garage, it's always clean. :)
Mike06train
11-29-11, 10:54 AM
When I bought the Denali, I was looking at an LTZ with power running boards. From what I've herd they have alot of problems.
hcvone
11-29-11, 11:17 AM
Never wanted them because of all the time we spend in upstate NY and the snow and ice has killed several of my friends Lincoln power running boards, having said that if you keep them turned off in those conditions, and keep them clean and lubed they seem to work well
71Dragtruck
11-29-11, 11:25 AM
They come on more then just the Platinum's, mine isn't a Platinum and came with factory power boards.
c1crx
11-29-11, 11:33 AM
Yea mine sit about where Murphy's do maybe I'm just nit picking lol
K9Caddy
11-29-11, 11:37 AM
Same here as 'Dragtruck'. Mine is a 2009 and has factory power running boards. I purchased mine brand new with this option. I have no issues with my power boards and mine do have this "gap" as well. Not concerned about it at all.
prosseda
12-01-11, 03:27 PM
Does not have to be Platinum. For example EXT's have them and they don't make Platinum EXT's. Also Platinums did not start until 2008 but 2007 trucks could have them.
prosseda
12-01-11, 03:32 PM
Mine:
Just curious if you cut the board to fit the flap or only slid it to the back.
hcvone
12-01-11, 03:51 PM
The flaps fit if you move the PRB's all the way back in the adjustment
HarleyGuy357
05-29-12, 09:58 PM
All the same no adjustments.. dif colors look tighter.. Thats why u sould have bought a black one if you wanted it tight..
roadog1aj
05-31-12, 12:24 PM
Hah, Hahhh! Yeah, my EXT is black and they do "look" tighter, but have the same gaps as seen on Murph's Escalade. I did adjust them towards the back when I installed the front mud flaps, but like other's have said....there is no adjustment except forwards or backwards.
bigbash55
07-19-16, 11:10 AM
can someone share the procedure to adjust the front/rear for the running boards. Mine are rubbing on the 22'' tires when i turn.
roadog1aj
07-20-16, 04:15 PM
There are allen bolts located under the running boards that allow you to adjust the boards forwards or backwards. You don't need to take them all the way out, just loosen them, adjust the board, then retighten.
