: NEED WINTER TIRES FOR 2005 CADILLAC STS - CAN I PUT 225x55x17'S ALL AROUND???
Detroit Mike
11-22-11, 10:47 AM
HELLO,
I HAVE 2005 CADILLAC STS (REAR-WHEEL DRIVE) AND AFTER HAVING A TERRIBLE TIME LAST YEAR IN THE MICHIGAN SNOW, I AM IN SEARCH OF SNOW TIRES FOR THIS WINTER. MY LOCAL TIRE GUY SUGGESTED FIRESTONE WINTERFORCE (225x55x17) ALL AROUND, HE SAYS ITS A QUALITY TIRE AND NOT AS EXPENSIVE AS BLIZZAKS...MY CONCERN IS THE DIFFERENCE IN SIZE, MY OEM RECOMMENDED TIRE SIZE IS 235x50x17 (FRONT) & 255x45x17 (REAR)...DOES ANYONE KNOW IF THIS SUGGESTED TIRE SIZE (225x55x17) WOULD CAUSE ANY ISSUE AS FAR AS HANDLING OR PLACEMENT ON CAR? ANY HELPFUL INFO WOULD BE APPRECIATED AS I HOPE TO TAKE CARE OF THIS, THIS WEEKEND
aksel79
11-22-11, 11:38 AM
Yes, you will have no issues other than your speedometer will read about 1 mph slow at 60 versus your stock tire size.
I installed the exact setup on my 2005 V8 RWD (Winterforce 225/55 17) a few weeks ago.
Detroit Mike
11-22-11, 11:55 AM
Thanks Aksel79,
What made you decide on the Winterforce and that particular tire size for your STS?
aksel79
11-22-11, 05:34 PM
Mike,
The 225/55 Winterforce are much less expensive than the 235/50 Blizzaks (about half if I recall correctly). Winterforce aren't available in 235/50, my Cadillac dealer recommended them and assured me there would not be any issues. They're only about a half inch larger in diamater than the stock 17's, and a half inch smaller than the fronts on a STS equipped with staggered 18's.
I run 255/45 18's all around in the summer, these are a 1/4 inch larger in diamater than the Winterforce.
The Winterforces do howl just a bit at freeway speeds and the handling is a little floaty at 75-80 but it's about what I expected for winter tires.
Thanks Aksel79,
JGarten
11-22-11, 11:09 PM
Actually, 55s are way taller than 45s (all else being equal).
Check out http://www.1010tires.com/tiresizecalculator.asp
They recommend <3% difference in tire size.
Stock Tire - 225/45R17 >Search
Tires (http://www.cadillacforums.com/forums/tiresearch.asp?treadwidth=225&profile=45&diameter=17)
Tire 1 - 225/55R17 >Search
Tires (http://www.cadillacforums.com/forums/tiresearch.asp?treadwidth=225&profile=55&diameter=17)
Section Width:
8.85 in
225 mm
Section Width:
8.85 in
225 mm
Rim Diameter:
17 in
431.8 mm
Rim Diameter:
17 in
431.8 mm
Rim Width Range:
7 - 8.5 in
Rim Width Range:
6 - 8 in
Overall Diameter:
24.97 in
634.23 mm
Overall Diameter:
26.74 in
679.19 mm
Sidewall Height:
3.98 in
101.09 mm
Sidewall Height:
4.87 in
123.69 mm
Radius:
12.48 in
316.99 mm
Radius:
13.37 in
339.59 mm
Circumference:
78.44 in
1992.3 mm
Circumference:
84.00 in
2133.6 mm
Revs per Mile:
832.9
Revs per Mile:
777.8
Actual Speed:
60 mph
100 km/h
Speedometer1:
56.0 mph
93.3 km/h
Speedometer Difference: -
Speedometer Difference: 7.084% too slow
Diameter Difference: -
Diameter Difference: 6.62%
Stock Tire - 235/50R17 >Search
Tires (http://www.cadillacforums.com/forums/tiresearch.asp?treadwidth=235&profile=50&diameter=17)
Section Width:
9.25 in
235 mm
Section Width:
8.85 in
225 mm
Rim Diameter:
17 in
431.8 mm
Rim Diameter:
17 in
431.8 mm
Rim Width Range:
6.5 - 8.5 in
Rim Width Range:
6 - 8 in
Overall Diameter:
26.25 in
666.75 mm
Overall Diameter:
26.74 in
679.19 mm
Sidewall Height:
4.62 in
117.34 mm
Sidewall Height:
4.87 in
123.69 mm
Radius:
13.12 in
333.24 mm
Radius:
13.37 in
339.59 mm
Circumference:
82.46 in
2094.4 mm
Circumference:
84.00 in
2133.6 mm
Revs per Mile:
792.3
Revs per Mile:
777.8
Actual Speed:
60 mph
100 km/h
Speedometer1:
58.9 mph
98.1 km/h
Speedometer Difference: 1.864% too slow
Diameter Difference: 1.84%
aksel79
11-23-11, 12:06 AM
Right, my summer rims are 18's. A 255/45 18 is about 3/4 inch taller than the stock 235/50/17. Edited my post above, originally indicated the summer tires were 245/45 18.
Section Width:
8.85 in
225 mm
Section Width:
8.85 in
225 mm
Rim Diameter:
17 in
431.8 mm
Rim Diameter:
17 in
431.8 mm
Rim Width Range:
7 - 8.5 in
Rim Width Range:
6 - 8 in
Overall Diameter:
24.97 in
634.23 mm
Overall Diameter:
26.74 in
679.19 mm
Sidewall Height:
3.98 in
101.09 mm
Sidewall Height:
4.87 in
123.69 mm
Radius:
12.48 in
316.99 mm
Radius:
13.37 in
339.59 mm
Circumference:
78.44 in
1992.3 mm
Circumference:
84.00 in
2133.6 mm
Revs per Mile:
832.9
Revs per Mile:
777.8
Actual Speed:
60 mph
100 km/h
Speedometer1:
56.0 mph
93.3 km/h
Section Width:
9.25 in
235 mm
Section Width:
8.85 in
225 mm
Rim Diameter:
17 in
431.8 mm
Rim Diameter:
17 in
431.8 mm
Rim Width Range:
6.5 - 8.5 in
Rim Width Range:
6 - 8 in
Overall Diameter:
26.25 in
666.75 mm
Overall Diameter:
26.74 in
679.19 mm
Sidewall Height:
4.62 in
117.34 mm
Sidewall Height:
4.87 in
123.69 mm
Radius:
13.12 in
333.24 mm
Radius:
13.37 in
339.59 mm
Circumference:
82.46 in
2094.4 mm
Circumference:
84.00 in
2133.6 mm
Revs per Mile:
792.3
Revs per Mile:
777.8
Actual Speed:
60 mph
100 km/h
Speedometer1:
58.9 mph
98.1 km/h
Detroit Mike
11-23-11, 09:42 AM
Hey guys,
Thanks for your reply, actually I made a mistake in my original post...my rear OEM tire recommendation is 255x45x17
JGarten,
Thanks for the tire comparision website, I used this and both my OEM recommended tire sizes (front & rear) are less than 3% difference in diameter/height
I will go ahead and try the Firestone Winterforce and reply back with my opinion once the snow falls...wish me luck! lol
