: Remove Driver's door panel
ESCALADE132
11-21-11, 03:02 PM
How hard is it to remove the driver's door panel. My son stuck a credit card down there and would think removing the panel it should be sitting in their right? The dealer said they might be able to do it under good will since im a good customer and its still under warranty. But if its not that hard ill do it myself. I was able to remove my radio and put in my own lock pick so i can do some stuff but don't want to start what i can't finish.
Thanks
luxurylife33
11-21-11, 04:38 PM
Very easy. Pop off mirror cover. Remove the small clip in the door lock tab. Pop the window control switch panel and unplug the wires, then theres 2 small panels that need to be popped to reveal a 10mm and one with 2 -10mm screws. Then just pull the panel as hard as you can straight out (toward you). Takes 5 mins at the most. Hopefully you understand my shitty pic!
http://i161.photobucket.com/albums/t222/luxurylife33/2007CadilallacEscaladeDoorTrim01Fixed.jpg
ESCALADE132
11-21-11, 05:44 PM
Wow great details Luxury after looking at this I will do it myself. The door unlock does that just pop off? Do I just pull up on it?
Thanks again for the great detail
DTEK01
11-21-11, 09:47 PM
Pull the little square out with something small it will pop off the rod then lift the whole thing up off the rod.
luxurylife33
11-22-11, 12:19 AM
yea just pop the square and the rest pulls up
luxurylife33
11-22-11, 11:20 AM
i misunderstood your question... yes the window switch just pops straight up. it comes off pretty easy, you dont need much pressure
Dirkdaddy
12-22-11, 06:14 PM
Thanks for posting this wasn't terribly obvious and hard to find information on web on this vehicle / year. :)
luxurylife33
12-22-11, 10:04 PM
no prob!
