iamstr8fire
11-02-04, 05:56 PM
My keyless entry pad which opens the doors,gas, and trunk is no longer working. Do I order another and if so how? Is there a way to just replace the battery?
| View Full Version : Keyless Entry Not Working iamstr8fire 11-02-04, 05:56 PM My keyless entry pad which opens the doors,gas, and trunk is no longer working. Do I order another and if so how? Is there a way to just replace the battery? brougham 11-02-04, 06:48 PM It's probably just that the battery is dead. Yes you can replace it. If there isn't a screw anywhere holding the remote together you just pry it apart. It should say in your owners manual somewhere how to do it. If you want to get another remote do a search for it here. There are several posts that say how to figure out what one you need and how to program it for your car. tco43 01-29-05, 09:16 PM When you replace your remote's dead battery, the remote often needs to be reset. This is explained in the owner's manual and also inside the battery cover of the remote. | |
