: 08 Lade running boards not functioning
dgarza
11-04-11, 10:26 PM
its weird drivers side is stuck down and passengers is stuck up. I feel this is an electrical problem because I do not hear any type of noise where the motors are trying to do anything... I checked fuses and everything is good there. Any ideas?
Thanks in advance...
99ssconv
11-04-11, 10:59 PM
you will have to use a scan tool to check for communication with the module and possibly reset the manufacturer enable counter to zero
dgarza
11-05-11, 12:16 AM
Would you care to elaborate a bit for me? I would really appreciate it. What type of scan tool could I use? How do I reset the counter to zero?
Million thanks!
hcvone
11-05-11, 07:15 AM
What works many times is to turn off your radio and HVAC system, disconnect the battery for 5 minutes and reconnect, see if that fixes the problem, it worked on a customers truck. :)
dgarza
11-05-11, 03:17 PM
Was really hoping it was that easy, but it didn't work...
Mike06train
11-06-11, 10:58 PM
I hear they power steps have alot of problems. They look great though.
hcvone
11-07-11, 07:05 AM
Then the dreeded dealer trip is needed. :(
jimwalston
11-07-11, 08:24 AM
i had to go to the dealer for them to use the scan tool.
dgarza
11-07-11, 10:59 AM
What was the repair they did to fix the problem? I'm out of warranty. How much did they charge you to repair it?
hcvone
11-07-11, 11:16 AM
Most will charge for an hour of time, if they like you they some times do it for free
dgarza
11-07-11, 02:32 PM
kool thanks
