: *** FAQ - DIY - Guides - How-To - Manuals ***
JimmyH
10-11-11, 06:39 PM
If you guys post links to other writeups and common info, I will organize here.
[EDIT: summarizing through post #7 -- MacMuse]
http://www.cadillacforums.com/forums...ml#post2741328 (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/242459-2011-srx-cabin-air-filter-step.html#post2741328) - 2011 replace cabin filter
http://www.cadillacforums.com/forums...-pics-how.html (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/194774-hid-fog-lights-installed-pics-how.html) - aftermarket HID fog lights
http://www.cadillacforums.com/forums...ry-models.html (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/221224-aftermarket-hid-lights-base-luxury-models.html) - more on HID
http://www.cadillacforums.com/forums...-2012-srx.html (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/237884-adding-fog-lights-2010-2012-srx.html) - installing the factory fog lights kit
http://www.cadillacforums.com/forums...accessory.html (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/221234-diy-adding-factory-fog-light-accessory.html) - more on factory fog install
http://www.cadillacforums.com/forums...ry-models.html (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/221224-aftermarket-hid-lights-base-luxury-models.html) - front bumper removal for access to lights
SRX Mods - including E & G Classic Chrome Heavy Mesh Grille, LED Lighting, Weather Tech Floor mats, DRL lightsl (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/194669-srx-mods-very-pic-heavy.html)
Upgrade your 2010-12 Side Vents to 13+ (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/318929-diy-how-upgrade-your-2010-2012-a.html)
How to Remove your back seats (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/386201-how-remove-back-seats-pic-heavy.html)
Replace your fuel vent control solenoid (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/392153-how-replace-vent-control-solenoid-p0449.html)
JimmyH
10-11-11, 06:39 PM
rtsittner
10-12-11, 11:26 AM
Here is my post on how to replace the fogs with HIDs.
Thanks for organizing this!
Randy
JimmyH
10-12-11, 02:36 PM
excellent. Keep them coming. Once we get enough, I will index it.
JimmyH
10-20-11, 05:38 PM
rtsittner
10-20-11, 05:52 PM
Here is one more posted by SRX2012...
http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/243104-removing-sliver-cover-over-gauges.html
bwclemons
01-09-12, 01:15 PM
Here are guides to removing the front bumper, adding Hid"s in the low beams of Base and Luxury cars and adding the factory Fog lights using the Cadillac Accessary kit.
http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/221215-diy-removal-front-bumper-access-lights.html
JimmyH
05-28-12, 07:51 PM
bump to get this off the new posts list (not sure why it keeps showing up)
bwclemons
05-31-12, 09:45 AM
Jimmy,
will you add "The Captain's" led light thread to the DIY's? Also, add the cabin filter DIY to the list.
JimmyH
05-31-12, 01:37 PM
need links
TheCaptain
06-24-12, 07:27 PM
SRX Mods including E & G Classic Chrome Heavy Mesh Grille, LED Lighting, Weather Tech Floor mats, DRL lightsl (http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/194669-srx-mods-very-pic-heavy.html)
JimmyH
06-24-12, 08:10 PM
You can add that to the first post. I am not at my computer right now.
Born Loser
05-17-13, 03:24 PM
replace the window motor (and how to remove the door panel), 2 parts: prt1 - http://www.youtube.com/watch?v=Lqn6d3Qwk6g
prt2 -http://www.youtube.com/watch?v=pkblpqQ6QZU
NVSRX12
06-04-13, 07:05 PM
remote programming
http://www.programyourremote.com/classified/Browse.asp?cid=136
adamjeeps
06-08-13, 10:52 PM
If you want to replace your glove box light with an led, simply take a plastic edge tool and pry the light down and toward the front. A dowel will need to back out of a hole (this is the switch to turn the light off when the door closes and pushes it.) Take your plastic edge and push the bulb out from the back of the socket because the bulb will be hot. Replace bulb with a small 194 led and reinstall light assembly. Enjoy your crisp clean led light!
chilleys
10-12-13, 11:39 PM
thank you.
Nice Ride
02-11-15, 06:59 PM
I did a post on a detailed Battery ( Type 48 AGM ) last year with photos. This week I added a bunch of info on xfer fluids 2010 srx under DIY. Would be nice to get them here for everyone else. The battery can also be used on the Escalade.
Just remembered I also did a complete write up with photos to do a MOTIVE brake flush on the SRX last summer. How can we search them and post relevant info here...?
Nice Ride
02-12-15, 11:51 PM
Diff Fluid Change
http://www.cadillacforums.com/forums/cadillac-srx-second-generation-forum-2010/576762-2010-srx-rear-diff-diy-fluid-2.html
Born Loser
10-03-16, 05:13 PM
Here is a TUT I made for the windshield washer reservoir.
https://youtu.be/XUNFwn1PpJQ
APU
02-09-17, 02:59 PM
Just wanted to say thank you to all the contributors
