: Please help for install ipad in my Seville 99
power007
10-11-11, 06:03 AM
hi
this is my first issue
i found some Products so i need help how is it work and is it easy to install in my Seville 99 factory boss system sound :thepan:
1-
http://www.shipsound.com/USA-SPEC-PA11-GM45-GM-Auxiliary-Input-and-iPod-Adapter_p_7290.html
81493
2-
http://pac-audio.com/productDetails.aspx?ProductId=37&CategoryID=36
81494
power007
12-27-11, 07:54 PM
:( no one
still_walkin
01-17-12, 08:29 PM
Is it a factory radio or aftermarket. If its aftermarket use a 3.5/RCA y adapter and plug the rcas into the HU aux input as for charging it you can use a cig charger to charge it. But if you want a clean install just get a cig charger take the cig part apart add a 10a inline fuse and wire it to constant 12v source on your fuse panel. Your hazards or radio/cig fuse could be an option too
power007
01-26-12, 08:56 PM
No it Is it a factory radio oem . All that I want to run the iPod without cutting wires
During my research the Internet and found this product is it good
thinks for help
http://www.ebay.com/itm/GM10AUXINPUTZUNE-/330178180771?item=330178180771&vxp=mtr
01ssreda4
01-27-12, 05:36 AM
Thats a steep little joker. How would you command the cd changer input when the changer would no longer be hooked up?
