: Fuel injector leaking at rail contact
greek97
10-29-04, 09:47 AM
I just replaced all my fuel injectors with re-manufactured injectors. After replacing everything looked great and ran great. Well the next morning I started my car and I started smelling gas. My car turned off automatically and when I looked under the hood, I noticed gas located near the back rail. I noticed that gas was leaking from the connection of the injector and the rail. I also noticed that the re-manufactured injectors had a gasket already on them so I can't see that being the problem. Should there be a second gasket within the rail :hmm: ? Please help :crying2: . Does anyone have a schematic of the assembly for the fuel injectors?
Car model:
97 Cadillac ETC
4.6L engine
eldorado1
10-29-04, 10:42 AM
Pull the rail off, and pull the offending injector off. Remove the o-ring on the top of the injector, and check the fuel rail to see if there are any o-rings stuck up in the hole. Remove them all. Go to nearest GM dealership, and purchase a injector o-ring kit. Reinstall "fat" o-ring on top (fuel rail side), and "skinny" o-ring on bottom (manifold side). I'd recommend replacing them for all of the injectors, but choice is yours. btw - make sure you lube them with something. I typically use fresh engine oil, but others might suggest something else... Good luck,
greek97
10-29-04, 11:23 AM
I will definitely give that a shot. Thanks for your help!!!! :)
BeelzeBob
10-29-04, 12:03 PM
Sounds like you need to pull the rail off and inspect that seal at the injector. I would also inspect the rail carefully for cracks or any splits. The process of R&R'ing the rail previously may have stressed it and cracked it or something.....or damaged it in some way.
eldorado1
10-29-04, 02:03 PM
Can the y2k models use the stainless fuel rail? Probably not since they use a different 'beauty cover' bolt scheme, but thought I'd ask....
EDIT*****Nevermind... Just read you have a 97... don't know why I thought you had a 2000 model... If you haven't already, upgrade to the stainless rail. The plastic 95-97 ones have been recalled. It's free of charge, PLUS, you get new o-rings as well! Save yourself $10 (I think that's how much the o-ring kit was)
greek97
11-01-04, 05:17 PM
Found the problem. It seem that the O-rings that came with the re-manufactured injectors were cracked. After replacing with AC Delco certified O-rings everything worked great. NO LEAKING. Thanks for all your help.
