: Oversize tires will work on the XLR-V!
coati
10-03-11, 10:44 AM
I decided to take the plunge and ditch the OEM Pirelli Euforia run flats for
brand new non-run flat Michelin Pilot Super Sport tires on the XLR-V.
Went with 245/40/19 front and 275/35/19 rear.
It looks much nicer now with a wider, lower profile.
So far so good with no clearance issues detected thus far.
deadringer
10-04-11, 11:30 AM
Photos?
Dr. Design
10-04-11, 08:22 PM
Hello,
Very cool. Are you running this on the OEM rim? If so how do the side walls feel under load? I would be concerned about the aggressive plus size on those rims as they are only 8+" wide. The approved rim width is 9.0-10" for a 275 tire. Everything might be just fine, but I would want to make sure you were aware of that and make sure you take the time to put some real side load on that combo before you put a lot of trust in that combination.
Thank you,
Dr. Design
D3 Cadillac
coati
10-04-11, 08:36 PM
Hello,
Thank you,
Dr. Design
D3 Cadillac
Thanks for your response and concern.
Yes, I am using the OEM 19", 8 1/2" width rim.
I'm aware of the recommended rim width of 9"+.
I haven't pushed it that hard yet in the corners.
They seem to be OK so far and the ride and grip is good, though initially the ride was a little hard.
coati
10-07-11, 12:22 PM
Photos!:)
Dr. Design
10-07-11, 09:38 PM
Looks good! Good job.
Dr. Design
D3 Cadillac
coati
10-08-11, 01:38 PM
Dr. Design
D3 Cadillac
Thanks Dr. Design!:)
frmula505
01-03-12, 10:28 PM
I have a Black XLR-V also. What are the tire diameters of the two sized you used? If they are different, did it affect the ABS, Speedo, Or traction control?
Thanks
coati
01-04-12, 12:48 AM
Thanks
The front diameter is slightly larger than the rear just like OEM.
Everything seems the same except the speedometer is slightly faster (1-2mph).
GizmoQ
01-04-12, 03:33 AM
I've run up to 285/35 rears with 255/40 fronts on my V and autocrossed it with no problem. But I run 18x8.5 on all 4 corners.
frmula505
01-04-12, 10:43 AM
I have 19x8.5 wheels for the front and 19x10 for the rear. Contemplating the size of tire I will go with. Would like a little more meat on the rears, due to the reverse lip on wheel (to keep the original offset). Thanks for your input.
