: Changing headlight bulbs in 2000
10-29-04, 12:18 AM
I have changed the low beam headlight bulbs in my 2000 Escalade and now want to change the high beams. One problem, how do I get to them??
I am installing Nokya Arctic White 100 watt bulbs. Any issues with going to the higher watt bulbs?
10-29-04, 08:45 AM
If you cannot get to the headlight assembly, I suggest you remove the grille cover......
Daryl in KY
10-29-04, 09:46 AM
I learned the hard way. Look in the owners manual, it show how.
10-29-04, 10:38 AM
you gotta pop the headlight. It has screws that you take out and then it should just slide out
11-01-04, 12:14 AM
I looked in the manual and sure enough it was ther. It was easy to change them.
Daryl in KY
11-01-04, 08:40 AM
It's interesting to me that changing the high beam just wasn't obvious. But the owner's manual saves a lot of guesswork.
