: Coolant Temp sensor , no partnr findable
notease
09-21-11, 03:31 PM
Good evening all Caddy lovers!
Dont know for sure ,if this is the right forum to post this engine related question ?
I recently bought a Caddy DeVille 1980 Strecht Limo vehicle,
On the front of the 368 6.0L Carb. engine is de the coolant temp sensor/coolant switch,
with 3 wires (brown,green,blue), 1 goes to the dash i assume for the Engine Temp Light and 2 to some kind of chip/ecu
for hot/cold running regoc.
The sensor wires are hard wired to the sensor, so the new sensor does have to have the 3 wires and a pigtail connector on it.
But the people here in The Netherlands cannot find the right partnr for it, i so do i.
It and the manuals only come up with a 1 wire/connector coolant sensor for 1980 year. But it does def. 3 wires.
Anyone got a clue and a partnr. ?
Greetings out of cloudy Holland
drmenard
09-25-11, 01:28 PM
You are not getting too much help here.. I am not up on the 1980 system... I know everything about the 81's.... If you could post some pictures and tell us what has gone wrong maybe we can help..
creeker
10-02-11, 10:38 PM
It's dark outside now, but I will look at my 80 cdv. tomorrow.
creeker
10-02-11, 11:31 PM
Wouldn't an 81 basically be the same except for the 8-6-4?
creeker
10-03-11, 02:34 PM
I looked at my 80-368 and I will need a better description of location of this sensor, I cant see anything thats obvious, is it on vertical or horizonatal part of engine,
what is it close to?.
