: D3 | Max Trackô Wheel Spacers
Dr. Design
09-20-11, 09:03 PM
D3 | Max Track™ Wheel Spacers
Hub Centric Wheel Spacers w/Extended Wheel Studs
Manufactured in the USA D3 Max Track™ Wheel Spacers are made from 100% Billet Alum. and manufactured to be an exact fit to the Cadillac Gen 2 CTS-V wheel hub.
D3 Max Track™ Wheel Spacers are made for drivers that wish to maximize the fit of their OEM wheels by pushing the wheels off the hub and outward towards the edges of the car.
Common uses:
* Pushing the front wheels to the edge of the fenders.
* Pushing the rear wheels to the edge of the fenders.
* Fitting the CTS-V Sedan rear wheel to the front of the car (D3 Square Setup).
$195 / Pair (2pcs) | USD
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-01.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-02.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-03.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-04.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-05.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-06.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-07.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-10.jpg
http://www.d3cadillac.com/wp/wp-content/uploads/2011/09/d3-max-track%E2%84%A2-wheel-spacers-11.jpg
Please let us know if there are any questions. For more information please visit our website http://www.d3cadillac.com/news/latest-news/d3-max-track%E2%84%A2-wheel-spacers or contact one of our sales reps.
Thank you,
Dr. Design
D3 Cadillac
MrMaschine
09-21-11, 05:53 PM
very interested D3 but how does these install since they are so thin? Can you explain whats involved if the OEM studs have to be pressed off the hub etc?
M5eater
09-21-11, 06:33 PM
you're slipping this over the OEM hub like any other spacer, the longer studs are there so you still have a good amount of thread on the wheel nuts.
Dr. Design
09-21-11, 06:44 PM
Hello,
Like M5eater already said the spacers are slipped/slightly pressed onto the OEM hub. The OEM studs are pressed out and the provided longer hardened studs are then pressed in. The longer studs ensure proper thread engagement when running the spacers.
Furthermore our spacers also allow us to run square tire setups on these cars. Running the square setup on these cars feel INCREDIBLE and allow us to carry even more speed when on the racetrack. So much, our drivers have been able to carry (1) gear higher in each turn at California Speedway running the ROVAL.
Thank you,
Dr. Design
D3 Cadillac
LV_V
09-21-11, 06:50 PM
Do you have any more details, i.e. how much further out the front and rear wheels will sit with these spacers? Any pictures close to parallel with the side of the car showing how much closer the wheel face and rubber is to the fender lip?
Great idea to put together a package like this that is tested for our application.
MrMaschine
09-21-11, 07:45 PM
D3 is pressing the old studs out and the new ones a huge job< approx how long is this? Do the wheel hubs have to be removed from the car?
I am going to have my installer shop call you guys to find more details and order them
Also i have an 18 winter wheel and tire set can I remove the spacers, retain the longer studs and retain the OEM lugnuts or i need different lugs to compensate for the different length of thread?
post up some more photos of the stance.
Cool!
Dr. Design
09-21-11, 08:26 PM
Hello,
Here are some quick shots from a recent install we did. D3 | Max Track™ Wheel Spacers installed front & rear on the square setup.
http://www.d3cadillac.com/graphics/releases/products/D3%20Max%20Track%20Wheel%20Spacers%20on%20car/d3%20cts-v%20max%20track%20spacers%20295-30-19%20all%20around-01.jpg
http://www.d3cadillac.com/graphics/releases/products/D3%20Max%20Track%20Wheel%20Spacers%20on%20car/d3%20cts-v%20max%20track%20spacers%20295-30-19%20all%20around-02.jpg
http://www.d3cadillac.com/graphics/releases/products/D3%20Max%20Track%20Wheel%20Spacers%20on%20car/d3%20cts-v%20max%20track%20spacers%20295-30-19%20all%20around-03.jpg
http://www.d3cadillac.com/graphics/releases/products/D3%20Max%20Track%20Wheel%20Spacers%20on%20car/d3%20cts-v%20max%20track%20spacers%20295-30-19%20all%20around-04.jpg
http://www.d3cadillac.com/graphics/releases/products/D3%20Max%20Track%20Wheel%20Spacers%20on%20car/d3%20cts-v%20max%20track%20spacers%20295-30-19%20all%20around-05.jpg
Thank you,
Dr. Design
D3 Cadillac
Speedtrapped
09-21-11, 08:57 PM
That looks great, me likey. But as mentioned I assume they have to be pressed in.
Dr. Design
09-21-11, 09:13 PM
Correct, the new studs will need to be pressed in. No way around that. But the fronts are pretty easy & quick.
Thank you,
Dr. Design
D3 Cadillac
