: 1993 Fleetwood idle issues Wont stay running L05 engine
09-15-11, 05:49 PM
Hey everyone,
I have a '93 Fleetwood with the stock L05 motor in it. Recently when i start the car it has trouble starting and takes a few pumps to get it fired. Once its running the idle is very very low. Low enough that 9/10 times it just shuts off. If i give it a little bit of pressure on the gas pedal it seems to run fine but once i take my foot off, it just bogs down and shuts off. Also, it seems to be a bit down on power... but that could be psycological seeing as these things arent exactly speed demons!
I just replaced the plugs with AC Delco DP's and the oil with Mobil 1 High Mileage (car has like 150k) and oil/air filters. Car ran great for a couple weeks.
From what I understand, the TBI has self adjusting idle and upon inspection the idle screw cannot be adjusted?
Could it be running on 7 cylinders? it seems to run a little rich by the smell of the exhaust but no misfiring or knocking. How do I check if one cylinder isnt running?
Please please please help me!
09-15-11, 05:58 PM
to me it doesn't sound like you're running on only 7 cylinders. have you checked the fuel filter and maybe the fuel pump? only reason I say that is because it sometimes is hard to start.
09-15-11, 06:35 PM
Both injectors working? If it smells rich than you're probably not sparking at all cylinders.
09-15-11, 08:13 PM
The idle screw CAN be adjusted, there's just generally no reason to adjust it so there's a plug over it....
You said you did plugs, did you do wires? Cap and rotor? Fuel filter?
Take a look at the injectors with the air cleaner off, make sure they're spraying nice even cones of fuel.
09-15-11, 09:11 PM
Mine started doing that before the fuel pump died.
