I am getting codes P0122 and P1122
P0122 Code - Throttle Position Sensor/Switch A Circuit Low Input
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
I figured I can replace the TPS first, as I am also showing the usual signs - car drives itself, high RPMs in park. etc
I just have one question... How do I get to the bottom screw? I really do not want to put coolant all over my floor... again... I have found a few posts to changing one out, but no one said what they used? Is there a special tool I need besides the torx bit?
Aside from that, I just need to do a TPS relearn, correct? I heard of two different procedures, one is to just unhook the battery for 10 odd minutes, hook the battery up, and then start the car and drive it, and the other is much more complicated than that. Which one is the one that I should use?
