: Cadillac Brougham - Cruise Switch Control Panel
Filip Dymák
09-14-11, 10:35 AM
Hello, I have Cadillac Brougham d´Elegance 1988 and I am looking for Cruise control swithch panel. Need to buy new. It is situadet under the Light switch panel. Can you help me? Filip
09-14-11, 03:31 PM
Unfortunately that part is discontinued, so it would be difficult to find a new one. There may be New Old Stock ones available on eBay, but the prices will be astronomical and the seller might not ship to your country.The switch itself doesn't fail too often, so a used one would be a good alternative.
Normally, when the cruse control stops working, it because of vacuum leaks in the engine. The cruise control servo (it sits on the front of the engine) could also be malfunctioning. There could also be an issue with the linkage that connects the servo to the throttle.
What exactly does your cruise control system do, that makes you think it is the switch? With a description of what is happening, we can help you diagnose it and figure out what parts you need.
