: Which is worst? Transmission problems or Trunk Pull Down problems?
Barrister_07101
09-14-11, 03:51 AM
Unfortunately my trans in the 1995 Black FWB (Black Beauty) is giving up the ghost I think. That would normally cause me MAJOR annoyance. But the Blue Devil (the 1994 FWB) has a great rebuilt trans in it. I haven't gotten it back on the road since it was hit in the front right during a blizzard a year and a half ago and on the front left by a garbage truck a few months after that. And then when I pop the trunk to get a rag to check the fluids ... no more trunk pull down. Of course both of these would happen at a 11:50 pm!
Well I'll call the mechanic get an idea of swapping/switching trans. I was hoping to get the Blue Devil on the road. Now I'm not so sure as I might just cannibalize it for the sake of the black one. (pretty annoying as I put a great suspension in it too) Now I have to troll ebay and/or fix the trunk pull down.
Any thoughts/suggestions/prozac? LOL
P.S. - The Blue Devil's trunk pull down never worked.
:annoyed:
brougham
09-14-11, 04:11 AM
You're kidding right? Comparing bad trunk pull down to dead transmission? Just crank it down by hand and disconnect it and call it done till you can hit up a junk yard for another one.
MoistCabbage
09-14-11, 05:22 AM
Which is worst? Transmission problems or Trunk Pull Down problems? :holycrap:
outsider
09-14-11, 08:32 AM
rofl.
trunk pulldown motor: probably under $100...like 10 minutes to fix
transmission: over $1000 and many hours.
turbojimmy
09-14-11, 01:08 PM
rofl.
You can fix the pull down issue for free. Just drill the rivets out of the paddle switch, clean out the inside and reassemble. Worked for me on both my Fleetwoods. Failed on an Eldorado, though. Not sure why.
The transmission isn't a terrible job, but it's time consuming. But if you have a good rebuilt one on-hand, it's just time.
sven914
09-14-11, 03:34 PM
Without the pull-down motor, how are you going to hide the evidence?
outsider
09-14-11, 03:45 PM
Duct Tape, sven :)
turbojimmy
09-14-11, 07:20 PM
Duct Tape, sven :)
And Hefty Lawn & Leaf bags.
Stingroo
09-14-11, 07:25 PM
http://www.youtube.com/watch?v=d0D5OWfdyTk
425 Dual Quad
09-14-11, 09:15 PM
Trunk pull down! Drives me nuts. Have disconnected both on the 94 and 93 FWBs until I get time to re-do them both!
Trans have been bulletproof on both!
thefleetwoodguy
09-15-11, 01:18 AM
there are some differences between the 94,95 and even the 96 4l60e trans
putting the 94 into the 95 requires some mods
or youll cook it in short order....sorry to be the bearer of bad news
MoistCabbage
09-16-11, 12:10 AM
No big deal, just throw a third transmission in it. At least it's not something serious, like a pull down motor. :sneaky:
thefleetwoodguy
09-16-11, 12:35 AM
your right them damn pull down motors are a bitch!!
Barrister_07101
09-16-11, 10:58 PM
But YOUR post said it would be ok with the exception of a silent code. Click Here (http://www.cadillacforums.com/forums/cadillac-forum/t-137406.html) to see.
csbuckn
09-16-11, 11:11 PM
I dont think thats the same guy. Good info though.
96Fleetwood had those purdy Broughams
Fleetwoodguy chops, cuts, rebuilds purdy Broughams.
drmenard
09-17-11, 12:21 AM
just don't open the trunk.... or if you have to open it, just disconnect the battery first and use your key... open and close then reconnect batt....
thefleetwoodguy
09-17-11, 02:24 AM
all I can say for sure is a customer with a 1994
bought a low miles 95 trans off me and it was
burned up in less the a 1000 miles
my self , I would just rebuild the stock unit for
piece of mind , in the long run, you may just be waaaaay better off
I dont claim to be the no all! ..........
thefleetwoodguy
09-17-11, 02:28 AM
Dave
just plasma cut the rear section about 6" ahead of the tail lights
simply, replace with a good trunk pull down, weld, grind, and fill the cut and then paint to match
and viola , its all good!!....lol
Barrister_07101
09-17-11, 10:20 AM
I'm not say you're a know it all ... but it seems that a 94 would work in a 95 with little issue. The 94 I have has been rebuilt... and it seems that for the foreseeable future ... the 94 isn't coming back. P.S. You do know alot!
Cadillacboy
09-17-11, 05:53 PM
Tranny problems may cause you stranded in a road but pull down not . It must be frustrating and to make things a bit more spicy if you are carrying valuable items ha ha
Well, so far we have never had pull down issue
thefleetwoodguy
09-17-11, 06:43 PM
I guess I didnt word that very well
I didnt mean to imply you were calling me a know it all
it was more just a disclaimer
but if I remember right the 94 trans wont go into overdrive in a 95
however there is a fairly simple mod that will allow it to work
something needs to be staked in place
if you cant find the info, its been posted on this site many times let me know
I will dig it up
I guess I do know a good bit about this model but Im still always learning
Stingroo
09-17-11, 08:15 PM
This is the link you posted.
The post of tech info was from 96Fleetwood - not TheFleetwoodGuy. His info in that tech post is correct, your trans CAN be used, but modification is necessary. Swap 'em over, it'll run just fine, and then like the post says, perform the mod to get the TCC lockup to work and allow you to go into overdrive:
An additional wire must be run from the PCM pin TBD to pin TBD on the trans harness for the TCC to work. Also, the PCM must be reprogrammed with ’95 transmission base code.
Good luck, it'll be good to get one of them back on the road. :)
Barrister_07101
10-04-11, 09:56 PM
Ok not that anyone cares ... here's the update ... rebuilt the trans $700 and will order the trunk pull down motor.
lowellches
10-11-11, 10:39 PM
How ? Please.
how do you "crank it down by hand" ?
Where is the crank ?
L
