: New V owner in Phoenix + some questions
Nate37AZ
09-11-11, 12:48 AM
Hey all,
Just picked up this new-to-me 05 V last week. It had 88,000 miles when I bought it and looks to be completely stock. So far I love it. :thumbsup: I'm in the middle of a 1000-mile roadtrip and the car has been awesome so far!
http://i105.photobucket.com/albums/m230/96cz28/CTS-V/DSCN2355.jpg
http://i105.photobucket.com/albums/m230/96cz28/CTS-V/DSCN2356.jpg
So one question that I haven't been able to find an answer to on here. The car has had some strange noise that I hadn't been able to pin down until today. It is a rattle/clattering noise that only occurs when the clutch pedal is all the way out. If I push the pedal in, the noise goes away. This definitely happens when the car is in neutral, but I can also hear it if I'm idling in gear. The clutch otherwise seems to be fine (only a tiny bit of chatter when going in to 1st), but I will do the 6th-gear clutch-slip test that was suggested on here tomorrow. Any ideas what this noise could be? Would bleeding the clutch lines help?
Thanks!
AmigoBB
09-12-11, 04:51 PM
I'm interested in this answer as my car (07 V) seems to be doing the same at around 60,000 miles. I live in Scottsdale, maybe it is all the dust storm (haboobs) wreaking havoc on our cars, jk. But seriously, six dust storms this summer, come on!
rand49er
09-12-11, 05:06 PM
Throwout bearing?
EdmundGTP
09-12-11, 05:07 PM
Throwout bearing?
That'd be my guess..
Nate37AZ
09-13-11, 01:48 AM
No kidding, this summer has been pretty bad!
In post #4 of this thread, http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/187681-2005-cts-v-vibration-whining-noise.html, I found this bit from the service manual:
The checklist in the service manual for Clutch Rattle, with clutch engaged or disengaged, is as follows:
1. Idle rattle clutch engaged replace engine flywheel due to faulty springs.
I also found this article, which suggests that it might actually be the pressure plate: http://www.cartalk.com/content/columns/Archive/1999/April/10.html
Their explanation seems a little weak to me, but I don't have a ton of experience with these things. The symptoms in that article are also exactly what I'm experiencing (except it's not really a tick noise). Any opinions? I guess either way you have to pull the trans, so at that point you can just look at the PP and see if it's bent, and then replace that and/or the throwout bearing and/or the flywheel.
Skidmarcx
09-15-11, 02:26 PM
Could be a worn throwout bearing, but normally you'd get a definite noise while disengaging the clutch... the pressure plate is most likely warped... I know mine is and I've got 65000 miles... chances are you'll need a clutch soon with that mileage anyways...
Oh and welcome to the V family :) I'm over in north Glendale
CTSV_Rob
09-15-11, 10:10 PM
Welcome to the forum and nice ride.
The stock flywheel is a dual mass flywheel. If you still have that flywheel installed (since you pointed out it seems all stock then it probably is) this could be the problem. I was a bit surprised when I pulled mine how much play it had and there was only 6,000 miles on it. I am no expert but I would think that with the clutch pedal out adn in neutral it is probably not the throwout bearing since it shouldn't even be touching the pressure plate but I could be wrong on this.
So my 2 guesses:
1- Bad flywheel
2- Bad pressure plate
BTW, that flywheel by itself weighs just short of 50 pounds by itself. you can shave a little weight off of the V and make it a lot more fun to drive by changing that.
Welcome to Mod Hell!!!
Nate37AZ
09-16-11, 02:10 AM
So my 2 guesses:
1- Bad flywheel
Thanks, this seems like a pretty sound explanation to me. Any reason why it might be a bad idea to continue driving it like this for a few months? I'd like to get a few other little things taken care of before I drop a big wad of cash on a new clutch/FW/PP. The LS7 setup looks like a nice way to go, though. Is the reliability as good or better than the stock setup?
Oh, and to the other Phoenix people, are there any local V meetups? It would be cool to get to know a few others with this car...
CTSV_Rob
09-16-11, 07:42 PM
I don't know how loud it is so hard to say. I would guess you would be fine but if you want to be sure I would take it to a shop you trust and see what they think.
I was thinking about the LS7 clutch and I think it's okay but when I pull the trigger I am pretty sure it will be the LS9 setup. no spacers required and you can use the stock slave cylinder design.
I have heard good things about this setup.
http://store.katechengines.com/ls9r-clutch-for-cadillac-cts-v-p248.aspx
I have heard the clutch feels stock but it can hold some serious power.
AmigoBB
09-16-11, 07:43 PM
When it drops a few more degrees, Pavillions! I know I told some forum people I would see them there this summer. Hopefully when it cools down a bit I won't be able to use the weather as an excuse.
Phx04CTSV
09-16-11, 10:40 PM
I'm down for a trip over to the Pavillions! Just post the date or PM me.
Nate37AZ
09-18-11, 01:33 AM
That would be cool with me. I've never actually been out there, might as well check it out.
Rob, thanks for the info. I wasn't aware the LS9 clutch was an option; I'll have to do some reading on it. Seems like I had heard some issues with the LS7 slave having problems, so maybe this is the way to go.
