View Full Version : Its Alive !!! and i need help
Xdimmysayzx
09-08-11, 01:51 PM
Well I promised I would post a video, of my 69 finally starting here it is ;)
http://www.youtube.com/watch?v=bnk9_rfjTXQ&hd=1
The Cadillac bible helped so much lol, just needed some points and rebuilt the smog pump
Anddd... I need some help, what kind of transmission fluid are you guys running. It says Dexron II I believe Do they still sell this?
Stingroo
09-08-11, 02:17 PM
If I recall correctly, any newer Dexron fluid is compatible with older transmissions, but older fluid is not compatible with newer ones.
I believe they're on Dexron VI now.
outsider
09-08-11, 02:22 PM
A lot of people may not agree with this but in a pinch I decided to get the "universal" stuff that they sell at walmart...says "Compatible in all dexron and mercron transmissions" or whatever...never had a problem with it.
What sting said is right, any Dexron fluid (II or higher) will be fine.
CADforce69
09-08-11, 02:33 PM
Sounds well! :thumbsup: Probably points were dirty or rusted after so many years not running. This car uses Dexron II, though as Stingroo says, Dexron III or IV is ok but III and IV are more expensive and they wont make this old transmission work better. Im sure you can find Dexron II at most autopart shops. It was used by every automatic car until 90s arrived. Check there is no leak. transmissions out of use for long time use to have seals or gaskets damaged.
77CDV
09-08-11, 02:51 PM
Looking good, my friend! :)
Stingroo
09-08-11, 05:33 PM
http://www.google.com/#ds=pr&pq=dexron&hl=en&sugexp=gsis%2Ci18n%3Dtrue&cp=8&gs_id=2x&xhr=t&q=dexron+2&qe=ZGV4cm9uIDI&qesig=DkqO5He5sQ8CQsxtZ2QqGQ&pkc=AFgZ2tn_Tetz3E6jt_ctmlp7WDjTxOhrxSePz_h48AuAhg EQJGlemAYNfWilEGRLIoNH4QJDqCipgtrgkNbpuDdc9mBD4-s0pQ&pf=p&sclient=psy&tbm=shop&source=hp&pbx=1&oq=dexron+2&aq=0&aqi=g1&aql=&gs_sm=&gs_upl=&bav=on.2,or.r_gc.r_pw.&fp=b21aeac2d6e9f9cb&biw=1360&bih=639
In case you are having trouble finding it... :)
Xdimmysayzx
09-13-11, 05:45 PM
Alright tranny works! Had to take the car for a ride up the street without a hood lol, anyways replaced valve pan cover gaskets today and thermostat for precautionary measures. Next up is door pins and frame paint any suggestions ?
77CDV
09-13-11, 07:11 PM
If you're doing the frame, can't go wrong with POR-15.
Cadillacboy
09-17-11, 03:12 PM
Thanks for the video , I liked your engine sound as well
