: Putting 2010 V on 4 Jack Stands
HuskerHoss
08-31-11, 10:14 PM
Ok, I am going to be taking all my tires off my 2010 CTS V to have them powdercoated. I will be putting my car up on 4 jack stands. I have read all of the threads on jack placement. Here are my questions.
1. Where is the best place to jack up the back of the car?
2. If I use the the jacking point on the rear, is there enough room to put a stand right there and the same time?
3. Is it better to jack up the car right inside the rear suspension on the frame and then place the stand under the jacking point?
4. I was planning on using the jacking points as a point to put the 4 stands, do you agree?
5. I was going to lift the front end first on the cross bar and put the front 2 jack stands under, then do the back, thoughts?
That is all for now, any suggestions would be great. Thank you.
thebigjimsho
08-31-11, 11:33 PM
Always tricky on my V1. And while I haven't had the V2 suspended on all corners, I'd probably do it the same.
I would back the V onto rhino ramps. Then I would jack up each rear side on the rear subframe where it bolts to the frame. Stick a stand under each side where the jack pucks go. Then from under the center of the car, I stick a jack under the front of the subframe and lift from there. Then stick a stand at each corner of the subframe.
Damn, I would love a lift...
Prof
09-01-11, 12:58 AM
Better idea...buy four Pirelli Sottos...put them on four new wheels, then send the old wheels off to be powder coated over the winter...and don't worry about jack stands at all...
M5eater
09-01-11, 09:03 AM
you could do the subframe in the rear like jim mentioned, and for the front I put mine near the pinch welds(most outboard location with a flat surface before the ''pinch'', it's also fully boxed and thicker steel), jacking up from the front subframe. i would refrain from putting the stands where the pucks go or anywhere on the front subframe. You *will* bend the thin metal where the lift pucks go and the front subframe isn't steel(source: experience), so I wouldn't put them on there either.
you see where the lift has a hold of this wonderful V2 in the front? Don't Jack (without a puck) or place the stands there.. it *will* bend that area. The area where it has a hold of it in the rear is where I would put the stands.
HuskerHoss
09-01-11, 12:01 PM
Thanks for the replies. I am a little confused still, sorry. Where exactly do you mean by the "pinch"? I am looking at the diagram somebody posted of the underneath of the V. Are you talking about putting the stands right where the front subframe meets the frame, but on the frame still? My other question is, if I look at the picture you sent, it looks like the hoist is picking it up by the rear jacking points, so I must be missing something. Please enlighten me more. Thank you again.
thebigjimsho
09-01-11, 12:07 PM
Where the jacking points are will be sturdy enough to lift the car. But if you don't use pucks, you will bend the pinched metal. It's not a big deal but, aesthetically, it will look crappy when it bends.
HuskerHoss
09-01-11, 09:30 PM
I am more concernced about where to put the jack stands and my other questions up above so if anybody has any more suggestions, I would take them. Thank you.
baabootoo
09-02-11, 12:32 AM
I don't mean to be filp, but why not where the manual says to jack the car? Lift the back at the differential, and find a second spot(s) for lifting the front. Put the jack stands under a 2" x 6" piece then.
MSOsr
09-02-11, 07:49 PM
Is there some place to buy jack plugs for the V2?
Mike (got V1 pucks from a BMW provider)
M5eater
09-03-11, 10:24 AM
I saw these in a thread a while ago,
http://www.cau-llc.com/cgi-bin/webstorecgi/webstore.cgi?page=01052&type=&frame=&cart_id=
post it up and I'll circle where.
HuskerHoss
09-04-11, 12:42 AM
Here is the link of the undernearth of the V that I was referencing. Thank you for your help.
http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/174795-jacking-cts-v.html
