: Supercharger POOF
mannyz
08-31-11, 05:22 PM
So...after getting that weird bearing noise i decided to remove my supercharger to check it out and send it in for a bearing replacement. Well I found more than I wanted to. A nice crack down the middle. Looks like I may need a blower upgrade so car will be out for a while. Check it out. Flame on!
Sounds it was making:http://youtu.be/6Fu6eITTxM0
Damage I saw:
79732
79733
79734
mannyz
08-31-11, 06:08 PM
By the way, 30K miles and my mods are 9.55 pulley, Intake, tune (done at 25K miles). So that's why I didn't bother taking it to the dealer. Its 2.5 hours away drive just for them to tell me no.
Razorecko
08-31-11, 06:19 PM
Wow, that sucks. 5K into the boost and it just split on you. How much boost were you pushing with your mods ?
gonfishin
08-31-11, 06:25 PM
It looks like it is on the opposite side of where the pulley is located, correct?
PremierJosh
08-31-11, 06:29 PM
Let me know if you are interested in buying my blower. My car has under 4k miles on it. Btw sorry for your issues but you just might help push me into a TT build.
mannyz
08-31-11, 06:30 PM
12.4 PSI boost. Crack is on the inside right after the snout on the actual core not the lid. those little numbers would be closest to you if you stood in front of the car.
neuronbob
08-31-11, 09:14 PM
WOW. That was a LOUD noise. I'd be mortified to hear that from my engine compartment. Be glad you discovered that crack before you lost the engine.....
thebigjimsho
08-31-11, 10:36 PM
Yikes!
Razorecko
08-31-11, 10:53 PM
Is it possible that the crack developed when the pulley was "pressed" ? and didnt open up and allow depressurization until after the few thousand miles
Prof
08-31-11, 11:50 PM
Horrible sound...I would do an oil analysis to be sure that you were not feeding metal filings into the engine...hope that is not the case.
mannyz
09-01-11, 12:01 AM
The pulley was not pressed as this was the lower pulley upgrade.
baabootoo
09-01-11, 11:38 PM
Just get it welded......
mannyz
09-02-11, 05:00 AM
^^^ I think i have some gorilla glue laying around that would be better :P
FastKat
09-02-11, 09:15 AM
How big/deep is the crack? Can you get your fingernail into it?
mannyz
09-02-11, 10:20 AM
Ill check when I get home but it seemed like I could fit my nail in there. Also, Im sure the noise I was experiencing was related to it so the Blower must have been affected by it.
PGA2B
09-02-11, 11:52 AM
Never mind...... Just read Jesse's post......
FastKat
09-02-11, 02:04 PM
Wow - any ideas what caused that? I wonder if the spring-loaded coupler has anything to do with preventing this kind of damage. Do you have a solid coupler or a stock spring-loaded coupler?
mannyz
09-02-11, 03:12 PM
Everything on the blower was factory including the upper pulley (no porting etc.). Also, the blower has never been touched apart from changing the belt when doing the lower pulley upgrade. I heard of this happening to someone else so it may have been a weak unit from the factory. Before I took it apart I kept getting that howling sound described in another thread. That individual took his to the dealer and had it replaced under warranty. So if you get this howling sound.......better keep an eye out because it was more than a bad bearing for me.
