View Full Version : '05 CTS-V rear sway bar with bushings, great upgrade for '03-07 CTS - $50 + shipping
08-27-11, 12:07 AM
This is a stock CTS-V rear sway bar and bushings with ~60k miles on it. I installed a Hotchkis rear sway bar in place of this bar, hence I no longer need the stocker. This will be a nice handling upgrade for a V6 CTS, as this bar is significantly larger (21mm vs 16mm) than the V6 rear sway bar. A larger/stiffer rear sway bar will reduce understeer.
I am asking $50 + actual shipping cost from 22310. Shipping will probably be a little expensive because the bar is obviously going to require an "oversize" box.
Do not send me a PM if you have a question or want to buy the bar - just reply to this thread. I will see your question/comment just as quickly, and it saves me from having to answer the same questions repeatedly.
10-20-11, 08:34 AM
Bump. Still available.
12-31-11, 09:20 AM
And still still available. Make me an offer.
01-29-12, 10:39 AM
Still available. I'd love to see this tested on a V6 CTS, I'm guessing it would make a pretty noticeable difference in the handling balance.
02-12-12, 10:32 AM
