: Oil Consumption WTF??
06BlackV
08-26-11, 12:29 PM
Whats up guys i got an 06 V with the ls2 ,,,, its currently got 68,000 miles and im losing about 1-1/2 quarts of oil every 2500 miles ,i would say im a conservative 50% of the time and a spirited driver the other 50% ,,,, is this normal?? i have no warrant either , anybody have an idea ?
heavymetals
08-26-11, 12:34 PM
The bulletin from GM states that if the LS2 (not sure about the other LS engines) sees higher than 3k rpms for a sustained amount of time then 1qt of oil every 3,000 miles is normal.
PISNUOFF
08-26-11, 12:51 PM
My stroker consumes an average of 1 qt every 1000 miles.
Houdini
08-26-11, 02:37 PM
My ls2 consumes oil but it is nothing that alarms me anymore. If you do a lot of 3k+ driving like heavy said, or do a lot of engine braking, it will consume more. GM will only do something if you burn more than 1qt every 2k miles. Yeah it's a ridiculous amount but that is the way it is. If you're burning more than that, then you have a problem and should get it checked out.
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/208525-why-does-my-v-eat-oil.html
GDPossehl
08-26-11, 03:59 PM
Get a catch can setup. Then at least you won't be eating it.
rand49er
08-26-11, 04:59 PM
Hm-m ...
My LS6 sips MAYBE a tablespoon every 3k miles.
PISNUOFF
08-26-11, 07:04 PM
I have one, still consuming copious amounts of oil.
PISNUOFF
08-26-11, 07:06 PM
Hm-m ...
I bet I could get it to consume oil. LOL
CTSV_510
08-27-11, 11:03 AM
Hm-m ...
Never passing 3000 rpms = no oil consumption. Got it.
mstrjon32
08-27-11, 11:28 AM
My LS2 spends a great deal of time north of 3K RPM...sometimes continuously (driving north of 100mph)...and so far it has not had consumption issues. On my last OLM-based OCI (from 100% to 5%...don't know the mileage) it didn't need any top-up oil.
whisler151
08-28-11, 03:26 AM
Mine was the same way. Added an oil catch can and the oil consumption seems to be normal.
Granted I just had the motor rebuilt due to a spun bearing.
catch2otwo
08-31-11, 10:44 PM
I just added a little under a quart to mine. Thats 3k miles including a trackday.
mberisha
09-01-11, 04:08 AM
Never passing 3000 rpms = boring
lucasmartin
09-01-11, 09:51 AM
Yet again you guys come through. I have the exact same thing with mine. I drive mostly highway and some city on the weekends. I am sure during normal acceleration I'm above 3k and I surely mess around with other cars on the turnpike. I have noticed that (going by my oil life percentage) I need to add just under a quart when I get in the high 30% range. I then don't have any other problems until the next oil change. Thanks for the info
lollygagger8
09-01-11, 10:12 AM
Man these truck engines are thirsty!!
CadzillaTN
09-01-11, 01:23 PM
"top it off and move on. as long as it's not smoking you're ok".
The end
mberisha
09-01-11, 01:35 PM
The end
.....and even if it is smoking.....it'll be alright.....
06BlackV
09-01-11, 01:54 PM
thanks for all the great replies!! so does anyone know the reasoning behind the consumption ? , and being that we have the vette motors, do we inherit their oil-ring problems?
heavymetals
09-01-11, 03:47 PM
Where do you get this from?
Oil-ring blow-by was a problem but is not inherent in "vette" motors (the LS2 is a truck motor also).
As for yours, maybe a ring problem so it is really a matter of you getting the thing apart and checking if it isn't sucking oil in through the breather.
Try not doing the "spirited driving" for the 50% of the time you claim you do for a few thousand miles (if you can) and measure the useage.
You might add a catch can and see if oil is in fact being sucked into the motor.
Also, it may not be rings at all.
Although this bulletin talks about different motors, it does apply:
http://nastfenews.org/index.php?option=com_content&view=article&id=77:excessive-engine-oil-consumption-in-certain-gm-trucks-and-suvs&catid=27:features&Itemid=49
Chubbilicious420
09-03-11, 08:03 AM
I just turned 100,000 miles on an 06. Never have to add oil with 5 to 6K oil change intervals. I engine brake all the time. Magnaflo sounds great on decel. Shift at 2800 to 3500 rpms routinely.
CadzillaTN
09-04-11, 12:06 AM
How many of you guys actually check the dipstick between changes?
How many of you have also seen ufos or bigfoot?
kevm14
09-04-11, 06:47 AM
Well I am 2600 miles into my last oil change. I drove the Dragon, hard, and other western NC mountain area roads last weekend and I just checked my oil: it's right at the top of the dipstick. Perhaps it's been said but I believe the LS2s are more prone to oil consumption issues than the LS6s in these cars.
