: 2008 STS Cabin Air Filter
Toolboynow
08-24-11, 01:41 PM
Where the heck is the cabin air filter located on a 2008 STS? Owners manual doesn't even mention one but I believe it's there!
Relate27
08-24-11, 02:29 PM
Not sure if it's the same place or not for your car but this is a really great write up with pictures.
http://www.cadillacforums.com/forums/cadillac-cts-first-generation-forum-2003/167683-diy-replace-cabin-air-filter-pictures.html
edit: Whoops I did't realize this was for the SRX boards..sorry.
Grunder
08-24-11, 05:51 PM
Pretty much like the above reply. Take the rubber off, 3 screws for the plastic, slotted air inlet, unhook the 2 side tabs on the water shield over the filter, and slide the shield to the center of the car.
Reach in and pull the old filter up - it's a b**** because it hits the back edge of the hood - I had to bend mine to get it out, and same with the new one.
John
R3TRO
08-25-11, 03:52 PM
Just changed mine this morning, got filter from RockAuto: http://www.rockauto.com/catalog/raframecatalog.php
What he said above:
-remove 3 screws with socket driver
-pull away weather strip
-remove rain shield
-unsnap water shield and remove
-pull filter out (will have to bend as it is a tight fit!)
-put new one in (also have to bend)
-put everything back reverse order
Good luck! Takes about 10min
