: Fuse locations and ratings for 1989 Cadillac Allanté
OffThaHorseCEO
08-23-11, 07:01 PM
The 1989 Allanté has 3 fuse panels
The main one is located under the ash tray and uses "regular" sized fuses
One is located in the battery compartment right behind the battery.
Lastly, one is located in the trunk, on the passenger side, in the same compartment the power antenna retracts into
The ratings and functions of the fuses in the "main" block are as follows:
COLUMN ONE
1 - (3 AMP) INSTRUMENT PANEL
2 - (5 AMP) CLIMATE CONTROL/DIC PANEL
HEATER AND A/C PROGRAMMER
LOW COOLANT LEVEL
AIR UP-DOWN ACTUATOR
3 - (3 AMP) COOLANT FAN
OUTSIDE MIRROR DEFOGGER
BODY COMPUTER MODULE
4 - (7.5 AMP) INJECTORS 1 4 6 7
5 - (7.5 AMP) INJECTORS 2 3 5 8
COLUMN TWO
6 - (25 AMP) WINSHIELD WIPERS/WASHERS
HEADLAMP WASHERS
CRUISE CONTROL
POWER MIRRORS
7 - (10 AMP) RADIO
8 - (15 AMP) BRAKE SWITCH
CENTRAL POWER SUPPLY
9 - (10 AMP) HEADLAMPS
PARK LAMPS
FOG LAMPS
TWILIGHT SENTINEL
INTERIOR LIGHTS
HAZARD WARNING FLASHER
RETAINED ACCESSORY POWER
RADIO
CHIME MODULE
10 - (30 AMP) SPEED DEPENDENT DAMPING
A/C LOW PRESSURE SWITCH
HEADLAMP WASHERS
COLUMN THREE
11 - (3 AMP) BODY COMPUTER MODULE
12 - (15 AMP) FUEL PUMP
13 - (15 AMP) VISCOUS CONVERTER CLUTCH
AUTOMATIC TRANSAXLE
CANISTER PURGE SOLENOID
14 - (10 AMP) ENGINE CONTROL MODULE
PASS KEY DECODER MODULE
15 - (10 AMP) BODY COMPUTER MODULE
CHIME MODULE
INSTRUMENT PANEL CLUSTER
HEADLIGHT REDUNDANT RELAY
THEFT DETERRENT
FUEL TANK UNIT
TAIL LIGHT REDUNDANT RELAY
COLUMN FOUR
16 - (15 AMP) TRUNK RELEASE
CONSOLE LIGHT
17 - (10 AMP) RADIO
CLIMATE CONTROL/DIC
18 - (20 AMP) CIGAR LIGHTER
FUEL DOOR RELEASE
19 - (7.5 AMP) CRUISE CONTROL
OUTSIDE MIRROR
WINDSHIELD WIPERS/WASHER
HEADLAMP WASHER
20 - (20 AMP) OUTSIDE REAR VIEW MIRROR DEFOGGER
COLUMN FIVE 21-24 ARE BREAKERS NOT FUSES
21 - (30 AMP) RETAINED ACCESSORY POWER
22 - (30 AMP) POWER DOOR LOCKS
POWER SEATS
MEMORY SEAT
23 - (30 AMP) RETAINED ACCESSORY POWER
24 - (30 AMP) REAR DEFOGGER
HARD/SOFT TOP PULL DOWN UNIT
25 - (20 AMP) UNDER HOOD LIGHT
TRUNK LIGHT
LUGGAGE COMPARTMENT LIGHT
VANITY MIRRORS
OVERHEAD READING/COURTESY LIGHTS
GLOVE BOX LIGHT
POWER DOOR LOCKS
The ratings and functions of the fuses in the block behind the battery are as follows:
MAXI FUSES - FROM BOTTOM TO TOP
1 - (20 AMP) OVER VOLTAGE PROTECTION RELAY
2 - (20 AMP) IGNITION
3 - (20 AMP) BRAKE SWITCH
LEFT SWITCH POD
RADIO
CHIME MODULE
BODY COMPUTER
4 - (20 AMP) ENGINE CONTROL MODULE
PASSKEY DECODER MODULE
5 - (40 AMP) POWER MODULE
TRUNK LID PULL DOWN UNIT
6 - (30 AMP) OUTPUT SWITCH MODULE 13
OUTPUT SWITCH MODULE 7
OUTPUT SWITCH MODULE 6
7 - (60 AMP) INTERIOR LIGHTING
EXTERIOR LIGHTS
8 - (20 AMP) DELCO-BOSE MUSIC SYSTEM
SPEAKER RELAY
POWER ANTENNA
TRANSCEIVER
The ratings and functions of the fuses in the block IN THE TRUNK are as follows:
MAXI FUSES - FROM TOP TO BOTTOM
1 - (20 AMP) BACK UP LIGHTS
HIGH MOUNTED STOP LIGHT
REAR SIDE MARKER LIGHTS
LICENSE PLATE LIGHT
INTERIOR COURTESY LIGHTS
2 - (20 AMP) LEFT STOP/TURN SIGNAL
3 - (20 AMP) RIGHT HEADLIGHT
FRONT SIDE MARKER LIGHTS
LEFT FRONT PARK/TURN SIGNAL
LEFT HEADLIGHT
LEFT FOG LAMP
Dajudge55
08-24-11, 11:39 AM
Thanks so much for the fuse locations and ratings. This is gonna help a lot !!!
Larry
