View Full Version : 1997 cadillac sevile sts windshield wipers dont work
Amilli23
08-18-11, 07:06 PM
My wipers dont work on my 1997 cadillac sts. The promblems started one day when the wipers on the driver side went over the window in the front and
came off alignment. I had fixed it back into alignment then again the wiper came to the drivers side and were stuck and the alignment was off. Then i
turned them off and since they never worked. Im just wondering what can be the promblem and what would u do to fix it ???
EChas3
08-18-11, 08:42 PM
You'll likely get the solution quicker in the Seville forum. This area is for the 2005 & up STS which is quite different.
Good luck!
Ronen911
08-18-11, 10:41 PM
the timing is off. It's a 2 minute fix. Most likely if you walk into a dealership they will fix it for you for free
Good Luck
also, check the fuse. that could also cause the problem.
Amilli23
08-19-11, 12:39 AM
k thanks can u send a link to the website please
Amilli23
08-19-11, 12:40 AM
thanks well i checked the fuse bbut im going to do what u said and go to a dealer ship
nathanjax
08-19-11, 12:46 AM
You need http://www.cadillacforums.com/forums...ldorado-forum/
