: fuel pipe and fittings
08-16-11, 06:42 PM
The steel fuel pipe found in the frame of the car, is it ok to use with a 40-60 PSI pump?
Also are the flares ok to use quick disconnect nylon lines from the pump to the pipe and from that pipe to the engine at the front of the car?
Or should the flares be redone with a different tool in order to use quick disconect lines?
08-17-11, 01:40 PM
I see there are tools to make different flares but they are way too expensive. I can probably buy the steel fuel lines with the good flares already on one end. For the other end I think I can rent a double flare tool and join my actual pipe with the new one with regular fittings.
