View Full Version : What to do.....
08-16-11, 08:06 AM
Whats The first step I should when I see the check engine light on? No dealers here. So it's DIY.
08-16-11, 01:21 PM
Check if your gas cap is tight, number one check engine light issue, second open the hood and make sure nothing is leaking, or hanging off
Dave DiGabriele
08-16-11, 01:31 PM
For around $50, you could buy a handheld code reader and know what the problem is.
08-16-11, 01:58 PM
If Onstar is active they can run the diagnostic test and give you the codes.
08-17-11, 09:31 PM
Canadian Tire might be able to scan codes.
08-18-11, 09:56 AM
Thanks for the Feedback.... Went to a local shop and luckily they had a techtool.... They said it's fuel causing an emission warning..... That won't change cuz we have 15% ethanol in our fuel here.
