View Full Version : problems starting
firstimecaddi
08-14-11, 10:51 AM
I've noticed recently that my 95 FWB sometimes will not not start on the first turn of the key when hot. For example, I recently drove about 45 miles, stopped to gas up but when it was time to get going again it took three turns of the key to get started. This has happened on a few other occasions and is not comforting. I've checked the codes but there is none that helps to pinponit a problem. What if anything can I check or be on the look out for?
jayoldschool
08-14-11, 11:13 AM
Need more info. When it is "not starting", is it cranking, or is there nothing happening?
firstimecaddi
08-14-11, 11:24 AM
crank but not start. kinda slow dragging noise
jayoldschool
08-14-11, 11:46 AM
Fuel pump. Keep your AAA card handy.
WMD
08-14-11, 12:07 PM
"Dragging noise" Have the battery and the starter tested and evaluated.
wmd
firstimecaddi
08-14-11, 12:30 PM
not necessarily dragging noise....that's my bad...
dragging, compared to the way it normally fires
must admit, have not had starter or battery checked lately, the battery though is about 2 yr old "Exide" brand.
jayoldschool
08-14-11, 12:49 PM
Clean and tighten the battery connections first.
lowellches
08-14-11, 02:18 PM
and check that you have a good ground
Barrister_07101
08-14-11, 07:47 PM
1. Clean and tighten the battery terminals;
2. Check that you have a good ground;
3. Have the charging system tested;
4. If all checks out and problem persists - pay for fuel filter and pump. lol
firstimecaddi
08-14-11, 08:51 PM
can a fuel pump be sourced at a junkyard or must it be bought new?
jayoldschool
08-14-11, 09:24 PM
Sure, you can find a used fuel pump. That's like finding a used condom.
Check your battery/starter/ground connections first!
HUF
08-14-11, 09:38 PM
Check your battery/starter/ground connections first!Jason, how many beers did you have tonight? LOL
If it only happens when engine is hot it is probably not the pump but rather starter/connections/battery/alternator/cables. Replacing a starter on LT1 may take less than 10 minutes.
