Greetings Cadillac Forums,
Thought I would get the opinion from everyone here before I start to assume. I started thinking my car had HG problems about last week when "Check coolant level" displayed for not even a minute, and then went away. I didn't think too much of it but did check my coolant level the next day when the car cooled off. I was a bit low, but I was wondering if that was because the mechanics did not get all the air out when I had a coolant hose replaced a year ago.
So now tonight, I picked up a test kit and ran a few tests. I let my car warm up and threw the test on the cap. First test turned green, I waited a bit longer as the temp was only ~190, and ran the test again when the coolant was around ~210. As I was finishing up the test, coolant started spewing out of the cap and I got some into the test kit. I know this cannot be normal, I have not been losing coolant that fast. I pulled some coolant out using a turkey baster and tried the test one last time. During the entire time the test was blue, until near the end, when I am guessing I started picking up coolant, as even more coolant spewed out of the car. This time the temp was ~224.
What do you guys think? Am I being paranoid? Coolant not under pressure has a boiling point of 220, or is that the green stuff? Would that explain the overboil? Or with how much coolant on the garage floor am I looking at the dreaded HG failure?
I should note too that during each test, I could not even pump the bulb at the top of the tube that you stick in the engine. I picked up a test that you manually suck out the air, and on it it states that if you cannot pump out air or if it remains blue, you should be worry free.
