Before i break it, How do you remove the power connector to the pump, there is a push tab but it doesnt want to disengauge and i dont want to break it.
Pull that tab up with a small flat screwdriver carefully and pull at the same time connector back. I do it with ine hand and without a screwdriver all the time with no problem.
"Up" means away from the connector... You do not need a screwdriver, just pull the tab with your finger sideways and up at the same time. You are not going to break it, do not worry.
While it is off, connect a test light or voltmeter to it , turn ignition ON and activate the pump. See if there is voltage at the connector. After you see voltage , do just that connect/disconnect the connector some 10-20 times to clear contacts and you will most like be all set.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
