Had an interesting experience in the '65 Convertible deVille on Sunday. I was coming back from a car show 2 miles down the road and the cooling fan bent some blades and embedded them in the radiator. Big bang, engine shut off immediately and coasted into the driveway, no real damage done.
I'm wondering what could have caused this though. The fan is a six bladed soft aluminium blade fan - is this original or an early flexalite of somehting? It has a date code of Jun 18 printed on the front and fits on a spacer not a viscous clutch.
As we were exiting the showfield the car sat a whole on some ground with rammed stones put down on the entrance in case it was wet so cars would not bog down. These fans create quite a tornado of air and I was wondering if it sucked up some stones which hit the fan blades and bent them over enough for them to catch in the radiator. Then when I acellerated up the road the engine rocked over slightly further pushing the blades into the radiator core. The ends of two of the blades were chipped by something. Seems a long shot but that is all I can think of. Engine mounts seem good and tight.
The fan had a finger's width clearance between the fan blades and the radiator but had no shroud. Engine has run fine on 6 hour plus journeys up to now, doesn't get hot in traffic but the heater doesn't really blow hot.
A buddy and I took the radiator out this evening and it seemed fine inside - pretty new actually, so I'll get it recored.
However I noticed there was no thermostat - just the 'ring' of the thermostat sitting in the housing with a load of crud embedded into the endge of it. The pipe where the heater coolant flow goes into the water crossover by the thermostat neck was pretty bunged up too so we cleaned that out but still there can't be more than a 1/6th inch passage.
My big question is
a) what caused it and has it happened to anyone else before?
b) should I straighten out the fan blades, get them checked for balance and put it back with an original shroud (there is one on ebay in Troy Michigan right now but kind of spendy at $100 for a fan shroud)
or
c) should I get a pair of 12" electric thermostatic fans and wire them up to a thermostatic switch so the fans come on at a pre-set themperature and go off at a pre-set temperature. That way I'll know the engine is running at the right temperature, it will warm up quicker etc etc. But it won't look original and electric fans make a differnt should than the turbine of the standard fan. The rest of the car is 100% original except for the yellow coloured spark wires and a 1 -wire alternator.
What's the general advice of the board? Put it all back original, fit a shroud, hope it never happens again, or be safe and go with the electric fans?
Advice please?
Thanks, Nick
My big question is
or
Advice please?
Thanks, Nick
