: Coolant T fitting leaking
07-17-11, 04:59 PM
Has anyone had problems with the coolant T fitting that sits on top of the radiator? mine is leaking under load. I'm about to chop it out and put in a brass piece, but I'm concerned that the OEM is so stout looking, and extremely expensive that it may have more function than i am anticipating...
07-17-11, 05:54 PM
No magic here - just plumbing. You can replace the T and any of the connecting hoses as long as the replacement compoents are designed to handle high temperature and a few psi of pressure.
07-22-11, 10:10 PM
Right on. No issues. Simple fix. Thank you.
