View Full Version : Anyone painted the fog buckets and rear grey piece as a DIY?
shade
07-16-11, 10:09 AM
Good results from over the counter products vs a shop? I know plastic is hard to paint so if you had good results please post up the products used to get the finished result. Thanks!
soon to V
07-16-11, 01:37 PM
I Carbon Fiber Wrapped mine after sanding down texture first.
Domsz06
07-16-11, 03:02 PM
shade use that new fusion stuff from krylon made for plastic. It's legit. I have not used it on my v, but on other plastics and it's amazingt! maybe paint the back side first and see if you like it?
LV_V
07-16-11, 05:28 PM
Is that the same carbon wrap material that TBJS used to wrap his exterior pieces? Will that hold up to the heat of the exhaust??
Or is this a real carbon wrap?
haterinc
07-16-11, 05:49 PM
i used 3M carbon wrap for that and its just fine... not sure what tBJs used but he had the right idea. he gets "props fo' sho" lol
LV_V
07-16-11, 06:24 PM
haha I hate to admit it, but the fake carbon wrap was pretty sick
soon to V
07-16-11, 09:15 PM
I like the gloss look of this brand. Its nothing but the local shelf stuff from Advanced Auto. No problem with exhaust heat yet. Been running it for over 3 months and no issues. I do expect it to not last too long (more than a year), but its an experiment and I will try some other stuff if it doesn't hold come winter. Note I don't take it through auto car washes, just power rinse by hand (carefully). I also use it on my center covers (wheels) and on front lower chin (also good bug protection). I should note that you need to take the whole piece off (not a quick job, but doable) and wrap it around all the edges real good. I also painted a small brush width on suspect edges to help make sure they didn't peel.
soon to V
07-16-11, 09:22 PM
detail
shade
07-17-11, 09:38 AM
Thats cool wrap where'd you get it?
shade
07-17-11, 09:40 AM
I ended up using similar stuff its called plasti dip that adheres like the fusion but then when it dries its rubber. Did some good prep work with the dremel and a finishing bit to scratch up the surface so hopefully no chips. I did buy the fusion just in case!
IRONDOG
07-17-11, 11:19 AM
Pictures please?
Rabbitctsv
07-17-11, 03:47 PM
Im from texas, I was in california and went to the Cars and Coffee in Irvine Ca. I met a lots of CTSV owners and checked out a lot of their cars, Also met the guys from D3, had some nieces cars, they have a big following.
When i was there I came across a california car Black 2009 with painted front fog light cups, painted grills with the chrome outer rings, and painted rear , I can say that the paint job was high gloss and matched the car great, it looks as if Cadillac painted this , It should have been factory, looks great, will try to find the pics tonight and post if i can.
s
thebigjimsho
07-26-11, 11:00 PM
I've had the 3M DiNoc stuff for over a year and a half and it still looks good. I had it installed by a tint/clear bra shop in the winter. Heat, cold, whatever, it holds fine. I've even scuffed the chin pieces and whatever gets scuffed off doesn't unravel or peel away. There are a couple of corners that have bubbled but a hair dryer or heat gun and it smooths right out like new. It still looks great and everyone thinks the car came like that...
http://pic90.picturetrail.com/VOL2241/2287429/22963540/382623587.jpg
http://pic90.picturetrail.com/VOL2241/2287429/22963540/382623339.jpg
http://pic90.picturetrail.com/VOL2241/2287429/22963540/382623326.jpg
http://pic90.picturetrail.com/VOL2241/2287429/22963540/382581450.jpg
