: changing to dual valve springs, easier to do with removing supercharger cover??
dvandentop
07-12-11, 01:40 AM
man these motors are about as bad as the fbody motors to work on it looks like being shoved so tight in there :D
i remember the days of my old LT1 trans and and putting in headers and spark plugs :bighead:
anyways any reccomended removals to make it a little simpler??
going to do cam swap end of the month most likely
wait4me
07-12-11, 02:45 AM
You can do them with the supercharger left on, just pull the valve covers, and spark plugs, then you can do them fairly quickly.
M5eater
07-12-11, 08:48 AM
agreed. All LS motors are super easy to work on with regard to this.
Rabbitctsv
07-12-11, 09:44 AM
if your doing a cam swap you should take the super charger off , you will need ( or most do it, I know i did ) to up grade to a solid isolator and to swap that out you will need to remove the supercharger. It takes all of 20- 30 min to do. i would do it to make this a easy cam swap.
wait 4 me has a great DIY on youtube.
dvandentop
07-12-11, 11:24 AM
there is alot of crap in the way, i have done several vette and fbody cam swaps already just seeing if anything to get outta the way on the V motor to make it a little more open work space like the vettes :D
gonfishin
07-12-11, 12:58 PM
I removed the coil wires, my valve covers and rockers to install new push rods. Take you time. No need to remove the SC cover.
PhxTriode
07-12-11, 03:18 PM
You don't have to pull the S/C for spring removal just mind the injector/coil harness. You only have to pull #8 and #1 coils to get to all the valve cover bolts. I leave the plug wires on the coils and the remaining coils on the valve cover and remove. It would be a good idea to get a 8mm 3/8's drive socket for the rockers.
The other plus side is if you are using a leakdown tester to charge your cylinders (to hold the valves in place) you can do your leak down at the same time.
Also the stock locks stick a bit and may require you to use a socket that is large enough to clear the valve stem and locks and a light tap with the cylinder charged to to free them before using your spring compressor.
One last thing is if you are going to a double spring you will have to remove the stock seals/spring perch and will end in some foul language as they are a pain.
Hope this helps
dvandentop
07-12-11, 07:25 PM
to get the stock seals off and seats usually just use a pliers to get the seal and a magnet to get the seats off
PhxTriode
07-12-11, 07:56 PM
They are one piece on our V's and pliers are tough to get where you need them doing it in the car.
zinner
07-13-11, 12:47 AM
Get ready for the sewing machine :) What cam are you putting in ?:thumbsup:
PhxTriode
07-13-11, 01:24 AM
No sewing machine with an LXL lobe profile...
zinner
07-13-11, 11:27 PM
I thought it was dual springs that made the noise not the cam profile. Anyhow in my 05 CTS-V you couldn't hear crap inside with the windows up and that head headers and an X pipe as well as a cam. I love the caddy sound deadening.
