There is a local guy doing Northstar head gasket repair that says he drills out the head bolt holes and re-taps them for a course 5/16” bolt and guaranties the job for 1 year.
Is it possible this would really do the job and hold up? Thanks
There is a local guy doing Northstar head gasket repair that says he drills out the head bolt holes and re-taps them for a course (sic) 5/16” bolt and guaranties the job for 1 year. Is it possible this would really do the job and hold up? Thanks
Not possible: the OEM metric thread head bolt is already larger in diameter than a 5/16" SAE bolt. (Original is M11 X 1.5........11mm is almost 1/2" in diameter to start with...........
New ideas come along all the time, some work a lot don't be careful with a new idea that cost not much different than studs by Jake. His stud kit is way over 400 completed jobs with no stud failures verses your local guy doing the work?
Yup, I’ll be getting the studs. I assume the jig that comes with them allows you to drill straight? Is it possible to do the job without pulling the motor?
Keith, Find Joe Tahoe's extensive writeup, with pictures, of his engine overhaul. It's all still in here..........down a couple of threads - 99 STS project.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
