: Service TPMS after recall repair
NC STS-V
07-07-11, 09:38 PM
Just had the passenger air bag recall done on my '10 CTS-V and on the way home I got the service TPMS message. It is the passenger side tires that are not being read.
I'll take it back to the dealer, but I'm curious if the TPMS issue is related to the recall work. Anyone else have this issue? I'm wondering if there is an antenna or something near the glovebox that may have been damaged.
smackdownCTSV
07-07-11, 10:02 PM
What recall was done? Mine had the passenger rear TPMS but it's likely related to my wiring issues. There's a TSB for the wiring.
gonfishin
07-07-11, 10:34 PM
Try the synch method described in your manual. Perhaps they rotated your tires or something.
JOEYCTS-V
07-07-11, 10:40 PM
What kind of wiring TSB is there?
NC STS-V
07-07-11, 10:52 PM
It was this recall:
http://www-odi.nhtsa.dot.gov/recalls/results.cfm?rcl_id=10V414&searchtype=quicksearch&summary=true&refurl=email
Dumb question - Can the tires be rotated? Obviously not front to back due to size difference, but I didn't think you were supposed to move them side to side either.
I'll check the manual for the resync directions.
gonfishin
07-07-11, 10:54 PM
You can rotate side to side. Maybe the resynch process will work and save you a trip.
smackdownCTSV
07-07-11, 10:55 PM
I'm not sure, I cannot find it. But I think I found mine!
2010 Cadillac Cts Service Brakes, Hydraulic Service Bulletin 97067
NHTSA: Action Number: 10038468 Service Bulletin Number: 97067
* Report Date:
May 01, 2011
* Component:
Summary: Gm: the brake, traction, or stability lights are on because of debris stuck on the wheel speed sensor. Updated on 06/15/2011. *kb updated on 06/20/2011. *rm updated 6/27/11. *pe
smackdownCTSV
07-07-11, 10:59 PM
Found it!
2010 Cadillac Cts Electrical System Service Bulletin 297884
NHTSA: Action Number: 10036550 Service Bulletin Number: 297884
* Report Date:
Jun 01, 2010
* Component:
Electrical System
Summary: Buick/cadillac/chevrolet/gmc/hummer/pontiac/saturn: additional diagnostic information for u0140 or u0073. Vehicle may exhibits some symptom(s) as door locks cycle while driving; intermittent no start; service stabilitrak dic message; spee
Caddyscat
07-08-11, 12:30 AM
My "service tire monitor system" comes on all the time! I had the dealer check it out while they were doing the same airbag recall work. He said he fixed it, but the message came right back on the same day. What a pain in the butt.
