: Wind whistle noise from front passenger side of vehicle
decathlon
07-03-11, 02:44 AM
I have a new three week old, 2011 Escalade, Platinum. Finally got up to 65mph highways speeds and could hear a constant whistle from front of vehicle with windows rolled up and air conditioner turned on. As I increased speed to the 75mph posted highway speeds the noise got louder. Noise is not mechanical. Took to dealer who put padding behind the front right headlight. Did not help. May have gotten worse. At 62+ mph I get a whistle wind noise that gets louder as speed increases. If roll right window several inches or all the way down at 65+ mph the noise gets extremely pronounced. Is not heard on drivers front window when down. Cannot drive any distances with window down on right side at 62+ mph speeds due to high whistle wind noise. Even with all windows up the noise at ascribed speeds can be easily heard. Cannot travel more than 30 minutes at these speeds, as noise is very annoying. Do all escalades have this problem? Hard to believe GM would sell $84,000 vehicles with these problems designed into vehicle.
hannity
07-03-11, 11:38 AM
Do a search on this forum for wind noise. It's a common issue.
MrHolland
07-03-11, 12:01 PM
I think i read somewhere about someone having an issue with the mirror whistling.
Cadillac Cust Svc
07-05-11, 03:49 PM
Decathlon,
I am sorry to hear that you are experiencing this issue. Have you been back to the dealership to let them know their fix did not work? If you would like, I can set up a case for you and send it to Cadillac Customer Assistance for review. Please send me a message with your full contact information including your VIN and current mileage if you would like me to set up a case for you.
Thank you,
Elizabeth, Cadillac Customer Service
decathlon
07-08-11, 03:23 AM
Thanks for the feedback received. As recommended, I researched the forum for wind noise (mirror). Seems logical that the right mirror might be source of wind noise. I notified my dealer the first attempt to correct noise didn't work. I told them of my research and associated recommendations on this forum. Have not had opportunity yet to schedule appointment with dealer to fix as their service department is only open M-F during same hours I'm working. Hope to get in soon. Will keep you posted on source of wind noise and fix required.
Cadillac Cust Svc
07-08-11, 11:26 AM
Decathlon,
You’re welcome. I am happy to help. I look forward to your update.
Thank you,
decathlon
07-17-11, 01:43 AM
2011 Cadillac Escalade platinum, 1,000 miles, just over one month since purchased new.
Took into a dealer yesterday to try to fix a wind whistle noise at highway speeds for second time. First attempt added insulation behind the right front headlight. This time dealer added insulation behind the right outside mirror. Again did not work. Each time they stated that they had taken vehicle for a test drive and stated had fixed. I also asked if dealer could fix one of the cordless headsets that didn’t work to DVD on passenger headrest. Dealer replaced headset; however it didn't work or match model sold with vehicle.
I thought I bought a high quality GM vehicle - disappointed that after two attempts dealers have not been able to stop an annoying wind whistling noise (that gets louder as increase highway speeds) to a new vehicle that costs $84,000. Unclear if this is a design issue or simply poor quality during vehicle integration & checkout.
This is a lessons learned to future Cadillac buyers – test drive new vehicles at highway speeds as well as city roads and do not let sales personnel talk constantly and keep radio turned on during the test drive. In addition, do not sign documents noting successful completion of warranty work until have tested with the dealer representative present to verify noted problems have been fixed. I will not make these mistakes again!
desidon
07-17-11, 06:57 PM
I have the same issue but on the drivers side. Been with the dealer 3 times no luck. My local dealer pretty much said that they cannot fix it any further. Took it to another dealer 100 miles away and still no joy. When I pick up from a dealer there is no easy way to test as I need to find a highway where I can do 70 mph.
I have researched all tsb's from the previous thread and given it to the dealer. They have tried insulation behind the mirrors etc but no luck.
I like my slade but this issue is really buggin the hell outta me!!
evois
07-18-11, 12:56 AM
it is not a mirror noise. there is a tsb for that noise in the stickies read it.
LakeGuy
07-18-11, 07:06 AM
I have the same issue in my '09. Haven't had it repaired yet. I suspect it is a slightly misaligned door. I've seen other forum posts pointing to that as a cause as well. Mine is worse with a crosswind which would seem to indicate it has something to do with the door instead of the mirror.
DG2
07-19-11, 09:13 PM
I just purchased a 2011 Escalade 2 weeks ago an this past weekend took her for a long drive from Long Island to Stroudsberg Pa. I drove mostly high speed ( 65mph ) and never heard a whistle noise. I have a trained ear for these things and am pleased to report she is as quite as can be. Did you take a look at your top rail cross bars ( on the roof ) ? Sometimes, if the front cross bar is too far foward you may get wind noise. I had a Buick Enclave and installed the cross bars afterwards ( they did not come standard ) and did notice that when I had the front cross bar in the wrong position I would hear lots of wind noise. Worth taking a look.
Did you install any other aftermarket items, window wind deflectors for or even mudflaps ???
:thumbsup:
decathlon
07-20-11, 02:44 AM
I have not installed any external aftermarket accessories. New car is stock from factory / dealer.
decathlon
07-20-11, 02:49 AM
New to forum. What does tsb mean? Please provide more info how to get to sticky or paste in a reply back. Thanks in advance!
Cadillac Cust Svc
07-20-11, 12:06 PM
decathlon,
TSB means Technical Service Bulletin. It provides technicians required new service information. It provides a correction to a specific product problem and usually contains repair procedures, information on part numbers and availability, and warranty labor code information. I believe the ‘stickies’ are on the front page of the forum. Please correct me if I am wrong forum users.
Thank you,
decathlon
07-29-11, 05:54 PM
Third time is the charm.
Took new Cadillac Escalade Platinum in to the dealer for third time to fix annoying wind whistling noise heard at highway speeds (62mph +). Dealer stated that they added additional padding behind the front right headlight to stop air from passing through at highway speeds. Upon driving home from dealer at highway speeds, the whistling noise is gone. Hopefully this will be a permanent fix. Dealer also replaced inop headset with a matching new headset. Time to enjoy my new vehicle.
Cadillac Cust Svc
08-01-11, 11:31 AM
decathlon,
I am glad to hear everything got taken care of. If you have any other questions or concerns, please let me know.
Thank you,
thompsonhonda
07-25-13, 05:13 PM
I too am experiencing the ssmae issue with a whistling noise sstarting @62mph and up, most prevelant at 75. the advisor at the dealer the first trip told me it was normal from the mirror to make that noise but I also owned another 2012, same trim level and all that did not make the noise at all. i have the truck back at the dealer today because the whistling is so prevelant its un bearable. they me just now and told me they drove a brand new platinum and the same noise came from it. if there is a tsb on this unit can you let me know what it is so I can tell them or call them and let them know. The pickle im in is I actually work for the same auto group that I take the truck to... is there any help you can provide
brian thompson
817.798.3903
hotrod55
10-01-14, 01:13 PM
I also have a wind noise problem with my 2007 Escalade. dealer replaced inner door weatherstrip, no change. replaced outer door weatherstrip, no change. with my permission they adjusted(bent) in the door some, no change. i wonder is there a problem with mirror, the small triangular interior piece where mirror attaches- you can push forward on the plastic at front edge of glass and the noise stops, this is not a weatherstrip, but is there a gasket under that mirror that may be the culprit ? sound drives u crazy. i have read all i can find on here but havnt solved the problem.
jeiler9865
10-01-14, 02:43 PM
Replace the door outer reveal molding, the gasket has been torn or compressed and no longer seals the door frame. Tsb on that
hotrod55
10-02-14, 10:11 AM
if by outer reveal you mean the one that goes around the top front door to rear door thats the outer weatherstrip i mentioned they replaced
dsminva
10-02-14, 11:01 AM
The reveal moulding is actually the black plastic part that fades, peels, etc. Its not a gasket.
ScarabChris
11-12-14, 09:55 AM
Ok guys, I had this noise until yesterday. Couldn't figure it out. On a separate project I removed the antenna and did a hidden antenna for a cleaner look. Noise gone! The damn antenna was making the noise.
dsminva
11-12-14, 10:15 AM
Pics of antenna or it didn't happen :)
ScarabChris
11-12-14, 04:27 PM
I did this.......
http://www.gmtruckclub.com/forum/threads/antenna-delete.73945/
dsminva
11-12-14, 05:02 PM
Wait - you have a "real" antenna? (had)
Never realized the EXT's had those. I was thinking you got rid of the shark fin!
So THAT got rid of your wind noise?
ScarabChris
11-12-14, 05:33 PM
Yes my EXT had a metal whip AM/FM antenna on the front passenger side. This is what was making the wind noise. Not the shark fin.
dsminva
11-12-14, 06:32 PM
Curious - did your antenna have a spiral going down (or up) it?
If not, then yeah major wind noise, but if it did, there should not have been any. That's what the spiral is for.
ScarabChris
11-12-14, 06:40 PM
It did not have the spiral. And I thought that was strange as every GM truck I have owned prior did have it. I'm guessing it was not the original antenna.
dsminva
11-12-14, 06:46 PM
Probably an Autozone special lol
Get the Escalade plastic panel and clean up the front, it will look better.
Glad you solved your issue!
ScarabChris
11-13-14, 08:20 AM
Yes I already have the panel without the antenna home on it's way here. Once I install it maybe I will post pictures. The truck really looks much better without the antenna.
dsminva
11-13-14, 09:15 AM
Might look more like an Escalade and less like a Silverado lol
