: How to get I Pod to work
06-28-11, 10:43 PM
Purchased a 2007 Escalade with an aftermarket I Pod wiring harness located in center console. It has I pod connection and headphone plug. Have no idea how to make it work or who's brand it is. Any ideas on how to get it to work ?
06-29-11, 01:14 PM
I just plug mine in and it mysteriously works. Since your car didn't have that as a factory option you might have to set the radio to aux, or something similar. Goodluck...
06-29-11, 01:49 PM
I believe that PAC makes the majority of these products, so try this link and see how it works. It is the reference card for PAC products. The stereo looks different but the buttons are the same. If this doesn't work, I will see what else I can dig up.
06-29-11, 08:49 PM
Could be a lockpick by Coastaletech....see the link below
06-30-11, 09:08 AM
If this is a PAC part... Select FM, then go back to XM, now you have 3 seconds to select the additional source you want to play. Do this by scrolling the knob on the right. Screen should say AUX1, AUX2 then IPOD. Once selected, you can play that source.
AUX1 means you can control the music from the ipod, AUX 2 means you listen to whatever is plugged into the 3.5 mm jack. IPOD means you control your ipod from the factory radio.
