: Navigation/ main screen backlight broken
danrob0123
06-28-11, 08:30 PM
My navigation system (stock) seems to have a broken backlight. The screen is black but all the buttons work and if there is sun shining through the sunroof I can faintly see what is supposed to be there. the radio still works and everything just can't see what I'm doing about 95% of the time. What should I do? is there a way of fixing it? If not, I'm thinking of buying a whole new unit on eBay for around $600 plus the cost of new buttons from Lindsay. I appreciate any help. Thanks
612WharfAvenue
06-29-11, 10:48 AM
Personally, I'd do the base CTS DIC swap and put a proper Double DIN Unit in under it. You'd end up spending close to the same amount but the end result would be way better.
CancerJCC
06-29-11, 02:20 PM
Prices for used NAV units are the same as the price for a replacement screen (I checked with some OEM manufacturers). Go stock CTS radio and custom touch screen like wharf said.
JDB
06-30-11, 01:37 PM
Just checking the basics first... do you have the switch for diming it turned off? ...up by the sunroof. Not sure if it can turn the light all the way out. Also, could it be part of the dawn/dust feature that auto-dims it? I assume it gets its readings from the auto-dim rear view mirror.
Who makes our NAV/radio? Because the build quality and quality control is aweful. I just had mine replaced under CPO because the 2nd one had some discoloration on the lower screen and the 1st one had the button enamel chipping off -- which I've been careful with finger nails and tell others before letting them touch it. Even this current one has a very tiny amount of discoloration and even one of button dots doesn't line up... saw others like this at V Day. Their template must be off...
heavymetals
06-30-11, 01:49 PM
I have been trying to find the vendor, but since it is a DELCO abortion, no one wants to be associated with it.
Another "great" product brought to you by GM interns who are clueless.
I mean really, how STUPID can a designer/engineer be to have a radio/nav system that cannot be swapped out without losing driving functions?
