: Updated mod list-guess the final HP/TQ
translux
06-27-11, 01:24 PM
Ok so the list of mods has slowly grown.
Will get done late this week early next by Jesse.
Manual trans with about 10k miles
Port/polished heads
Cam/springs
CAI
injectors
9.5 lower
BB cat back
snout port polish
plugs
solid isolator
heat exchanger
dyno tune by jesse
kirbyCTSV
06-27-11, 01:56 PM
nice mod list...manual or auto?
translux
06-27-11, 01:59 PM
Oh sorry manual trans with about 10k miles
gonfishin
06-27-11, 01:59 PM
625 ish?
translux
06-27-11, 02:02 PM
625 ish?
I would be thrilled with 625 safe HP as this is my only daily driver at the moment.
Also if something bad were to happen my wife would know something was up ;)
kcshaner
06-27-11, 02:07 PM
618 :)
wait4me
06-27-11, 02:11 PM
I say 640 but backed down to 620 to give you a 2 degree of timing safety window. With smooth idle.
kirbyCTSV
06-27-11, 02:53 PM
I remember Bushidopupil was at 600 with the same list minus injectors and heads...so should be around 630s...are u only porting the snout or full SC?
translux
06-27-11, 03:40 PM
Sounds perfect
Not sure Jesse?
xRUSTYx
06-27-11, 03:42 PM
629 .... i'm feelin lucky today!
wait4me
06-27-11, 05:06 PM
Well technically you can gain a ton more with just a cam swap, but the higher you go, the less drivability you get. So it is better sometimes to just fix all the other stuff to make the cam not have to be so big..
Same concept with our bigger displacement engine packages. We can make the same power "and more" but with alot less boost, so the engine isnt under as much stress, and isnt generating as much heat from the compressed air.
So, to keep things smooth and just add in more power, we choose to select a mild cam, and get everything else back in line.
wait4me
06-27-11, 05:08 PM
Depends on the amount of free time i have that day if i do a free blower porting or not.
translux
06-27-11, 05:28 PM
Drivability is key for me.
gonfishin
06-27-11, 11:56 PM
tlux,
I think you'll be pleased with the outcome. Enjoy.
zirotti
06-28-11, 12:33 AM
Love it E! Fantastic choice of add-ons.
Titaniumseeker
06-28-11, 12:34 AM
I'm guessing 611
aj660
06-28-11, 02:36 AM
Everything sounds good. You might want to consider headers/high flow cats and scratch the b&b catback. If not, then you'll need a cat delete pipe because the stock cats will most likely fail with your HP. Jesse will explain lol ...
translux
06-28-11, 02:16 PM
I thought that was a tuning issue...
aj660
06-28-11, 02:31 PM
Definitely not, at least in my case. 600+rwhp, 16psi, and my cats were toast. I lnew my car was missing a lot of power and I couldn't figure out the problem.
Last resort was getting rid of my cats and that was it..
translux
06-28-11, 03:24 PM
I'd be ok with high flow cats as long as it did not get much louder.
Jesse any feedback on this?
aj660
06-28-11, 11:10 PM
I agree, just go with headers with high flow cats instead of the B&B. It will sound great and not too loud. That's the route I should have gone. Unfortunately, I didn't know then what I know now...
You will spend about the same amount too because if you go with the B&B then add another 350 for the cat delete pipe.
hunterkiller
06-29-11, 05:42 PM
640 hp
translux
06-29-11, 06:41 PM
This is what Hennessey does so I guess it would sound like this...
http://www.nbc.com/the-tonight-show/video/2011-Hennessey-Cadillac-CTS-V/1323959
Sorry cant get embed to work...
